ThaiFiesta Posted January 12, 2017 Share Posted January 12, 2017 Hi, has anyone installed an air to fluid oil cooler in their 1.0 Ecoboost? I'm thinking to add one to increase cooling as it's always very hot here in Thailand. Pics are examples of what I've seen available, without spending a fortune like the Mishimoto one. Quote Link to comment Share on other sites More sharing options...
DieselPig Posted January 12, 2017 Share Posted January 12, 2017 On the one day a year it's hot in England I'd walk! 1 Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted January 12, 2017 Share Posted January 12, 2017 4 minutes ago, DieselPig said: On the one day a year it's hot in England I'd walk! He's in Thailand If it's compatible with your car go for it, just look for the cheapest one so it won't hurt your wallet so much, if you're unsure message the seller or give them a call to ask about compatibility 1 Quote Link to comment Share on other sites More sharing options...
dfriel2 Posted January 12, 2017 Share Posted January 12, 2017 Can't see this being needed. I used to live in the Middle East and there was no need for extra oil cooling on modern cars. 1 Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted January 13, 2017 Author Share Posted January 13, 2017 10 hours ago, dfriel2 said: Can't see this being needed. I used to live in the Middle East and there was no need for extra oil cooling on modern cars. Depends how you drive, I guess. There's little to no scope of increasing the water cooling on the 1.0 (unlike the ST where larger radiators are available). So deleting the water to oil cooler and replacing it with an air to oil cooler should aid in keeping the entire package within design limits when running hard at high temperatures. The Fiesta struggles here, with not much needed to push it to the limits. Quote Link to comment Share on other sites More sharing options...
dfriel2 Posted January 13, 2017 Share Posted January 13, 2017 Depends how you drive, I guess. There's little to no scope of increasing the water cooling on the 1.0 (unlike the ST where larger radiators are available). So deleting the water to oil cooler and replacing it with an air to oil cooler should aid in keeping the entire package within design limits when running hard at high temperatures. The Fiesta struggles here, with not much needed to push it to the limits. We used to do summer track days at the Dubai autodrome, never had oil temp problems. Knowing what effort goes into engine calibration for a global product, I wouldn't want to mess with the cooling system on a modern car..Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Eatonm112 Posted March 12, 2017 Share Posted March 12, 2017 On 13/01/2017 at 9:24 AM, ThaiFiesta said: Depends how you drive, I guess. There's little to no scope of increasing the water cooling on the 1.0 (unlike the ST where larger radiators are available). So deleting the water to oil cooler and replacing it with an air to oil cooler should aid in keeping the entire package within design limits when running hard at high temperatures. The Fiesta struggles here, with not much needed to push it to the limits. If it was me I would either fit a aftermarket gauge so that oil temp could be monitored OR use one of those bluetooth OBD port plugs with a bit of software on your phone and see if its possible to monitor it that way. You can also tell if the engine oil has over heated (120 Deg C or so) as it smells burnt but as the other poster said I very much doubt youll have any issues as Ford would have tested that engine is every climate going. If you are tracking the car with a re map and really do want to go for a aftermarket oil cooler my suggestion would be to use a Laminova oil to coolant type cooler as you cant over cool the oil as the heat is being dumped into the engine coolant system which is how the standard Ford oil cooler works apart from its much smaller. Another advantage of that style of cooler is it aids fast oil heat up from cold as the engine coolant heats up way quicker than the oil. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted March 13, 2017 Share Posted March 13, 2017 Just to add.. The 1.0 already has a factory oil cooling solution. It obviously could be better, but anything is better than nothing :) 1 Quote Link to comment Share on other sites More sharing options...
