GMX Posted February 8, 2017 Share Posted February 8, 2017 When she's up in the office, Pipper has taken to sitting on my headphone cable when she's under my desk/chair, and then curling up fast asleep. I don't like having to disturb her every time I want some music The headphones are plugged into the audio out on my Belkin SOHO KVM switch, so I can listen to my music which is stored across 4 computers, or from my phone via wi-fi. So, as not to disturb a sleeping Pipper, will cordless or wireless headphones work off a KVM switch? Quote Link to comment Share on other sites More sharing options...
Micro Posted February 8, 2017 Share Posted February 8, 2017 Should do? As long as they're the type that has a "base station" which plugs into the speaker/line out socket. If they're the bluetooth kind that link directly to the computer then no, unless your KVM switch has a USB pass through. 1 Quote Link to comment Share on other sites More sharing options...
GMX Posted February 8, 2017 Author Share Posted February 8, 2017 19 minutes ago, Micro said: Should do? As long as they're the type that has a "base station" which plugs into the speaker/line out socket. If they're the bluetooth kind that link directly to the computer then no, unless your KVM switch has a USB pass through. Thanks i have got two USB pass through sockets on it but they're already in use: so I'll get a base station type Quote Link to comment Share on other sites More sharing options...
Micro Posted February 9, 2017 Share Posted February 9, 2017 1 hour ago, GMX said: Thanks i have got two USB pass through sockets on it but they're already in use: so I'll get a base station type By pass through i mean they disconnect from one computer, and reconnect to the other when you switch computers. If they do, a usb hub should suffice? https://www.amazon.co.uk/wireless-headphone-computer-monitoring-earphone/dp/B00G82R0C0/ As an example only, the base station gets its sound via cable from the KVM switch. I don't own these, so can't comment. Quote Link to comment Share on other sites More sharing options...
jace1969 Posted February 9, 2017 Share Posted February 9, 2017 I'm looking at a similar problem so will be seeing if you solve this. Quote Link to comment Share on other sites More sharing options...
