D13 HPD 95 Posted March 25, 2017 Share Posted March 25, 2017 As per title really, wanting to stick some spacers on my stock ST wheels, thinking 20mm front and 25mm rear, has anyone done this to a mk3 and know they fit? also do the stock alloys havea recess on the mating hub to allow a little pock from the studs in the hub? cheers, pictures would help as well :) Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted March 27, 2017 Author Share Posted March 27, 2017 Bump anyone? Quote Link to comment Share on other sites More sharing options...
james_60 Posted March 29, 2017 Share Posted March 29, 2017 Hi Daniel May i ask why ? Do you have the stock 18" or the option 19" alloys. These fill the arches very well as it is. Just be carefull that the tyres do not rub the insides of the arches. Is your ST lowered or standard Jamie Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted March 29, 2017 Author Share Posted March 29, 2017 stock 18's and its lowered 15/20mm ive had a look and im sure 20mm spacers wouldnt course any rubbing, now its lower just need filling out a little more Quote Link to comment Share on other sites More sharing options...
james_60 Posted March 29, 2017 Share Posted March 29, 2017 Hi Daniel Ok fair enough, Would the tyres or rims rum on the suspension strut or cables etc. If no then go ahead and try it, but im sure someone more experianced will be along shortly :-) Wider track at the back may help at least Jamie Quote Link to comment Share on other sites More sharing options...
kpg Posted March 29, 2017 Share Posted March 29, 2017 I have 20mm spacers front and back on my MK3. No rubbing at all, looks great too. Going for 25mm in the rear soon though. Needs a little more poke.Before: Quote Link to comment Share on other sites More sharing options...
kpg Posted March 29, 2017 Share Posted March 29, 2017 Im on 35mm H&R springs btw Quote Link to comment Share on other sites More sharing options...
james_60 Posted March 29, 2017 Share Posted March 29, 2017 Thanks KPG now im hooked and want to do that to my st. was there anything else you need to do for that ? Where should i get the spacers from are the wheel studs long enough Jamie Quote Link to comment Share on other sites More sharing options...
kpg Posted March 29, 2017 Share Posted March 29, 2017 I got these:http://www.ebay.co.uk/itm/400995199803Everything needed is included in the kit. Just get two kits, 1x front and 1x rear. Just can use the 'make offer' function on eBay, i got two sets for £105 :)I recommended 20F and 25R. Needs a little more poke in the rear. Just wish my front suspension height was about an inch lower :(Sent from my HTC 10 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted March 30, 2017 Author Share Posted March 30, 2017 kpg - do you know if the stock ST alloys have the room behind them for the hub studs to still fit ok? yours looks good but different alloys to mine 1 Quote Link to comment Share on other sites More sharing options...
kpg Posted March 30, 2017 Share Posted March 30, 2017 kpg - do you know if the stock ST alloys have the room behind them for the hub studs to still fit ok? yours looks good but different alloys to mine Im pretty sure your alloys would be fine. I was recommended those spacers by the guys over at STOC. There's at least 5/6 STs like yours with the same kit and no problems reported.Sent from my HTC 10 using Tapatalk Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted March 30, 2017 Author Share Posted March 30, 2017 Sweet he's out of stock on the 20's but will order up when available :) 1 Quote Link to comment Share on other sites More sharing options...
ajzetecs Posted March 31, 2017 Share Posted March 31, 2017 i am have 20mm spacers for sale £35 delivered on my mk2 diesel, should fit mk3 st 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted March 31, 2017 Author Share Posted March 31, 2017 13 hours ago, ajzetecs said: i am have 20mm spacers for sale £35 delivered on my mk2 diesel, should fit mk3 st Messaged you mate Quote Link to comment Share on other sites More sharing options...
