KilpAr Posted July 26, 2017 Share Posted July 26, 2017 Hi, I have an Android phone that has been previously successfully connected to Sync. So no, this is not a brand new phone. Yes, Sync has had a connection to this phone before. It suddenly stopped connecting. As attached is the situation of pictures where I'm stuck. Basically everything is working but Sync informs me of a code that I can't change. On either end. I find Sync, but the codes doesn't match. Android (Huawei Honor 8) gives two options: Connect or cancel. No option to change the code. I don't find that option from Sync either. Things tried so far 1) Turned off Android bluetooth 2) Turned off Sync bluetooth 3) Restarted Android 4) Restarted Sync 5) Restarted car 6) Deleted Android from Sync 7) Deleted Sync from Android 8) Reseted defaults to Sync 9) Done Master Reset to Sync The next I'm going to do is a factory reset to Android, but do you have any other suggestions before I do that because it sounds like an overkill to me. edit. Well obviously could try with another phone too. Here's the result: Quote Link to comment Share on other sites More sharing options...
lwatson99 Posted July 27, 2017 Share Posted July 27, 2017 Try pulling the fuse of SYNC while the car is off, then putting it back in and restarting the car. I found this fully cleaned up SYNC and fixed issues I was having. 2 1 Quote Link to comment Share on other sites More sharing options...
KilpAr Posted July 27, 2017 Author Share Posted July 27, 2017 11 hours ago, lwatson99 said: Try pulling the fuse of SYNC while the car is off, then putting it back in and restarting the car. I found this fully cleaned up SYNC and fixed issues I was having. I saw this on YouTube and wondered if this applies to this kind of issue. Well, if you feel it really could, then sure, I'll give it a try. 1 Quote Link to comment Share on other sites More sharing options...
KilpAr Posted July 27, 2017 Author Share Posted July 27, 2017 12 hours ago, lwatson99 said: Try pulling the fuse of SYNC while the car is off, then putting it back in and restarting the car. I found this fully cleaned up SYNC and fixed issues I was having. You know what? That fixed it. Thanks :) 3 Quote Link to comment Share on other sites More sharing options...
