victor jones Posted December 21, 2017 Share Posted December 21, 2017 no pressure on clutch pedal had my master cylinder replaced 6 months ago checked for leaks in the car around clutch footpedal was dry shared hydrolic fluid and brake is fill half way looks ok cant tell because there shared been uner the car cant find the master cylinder under the car i have the haynes manual but i know thats not going to tell me where the master and slave cylinders are do i need to remove parts. i am hoping the master cylinder arm has came off a common problem but cant find where it is. give up on taking it to a garage at this time of year any advice to check the master cylinder and slave Quote Link to comment Share on other sites More sharing options...
victor jones Posted December 21, 2017 Author Share Posted December 21, 2017 11 minutes ago, victor jones said: no pressure on clutch pedal had my master cylinder replaced 6 months ago checked for leaks in the car around clutch footpedal was dry shared hydrolic fluid and brake is fill half way looks ok cant tell because there shared been uner the car cant find the master cylinder under the car i have the haynes manual but i know thats not going to tell me where the master and slave cylinders are do i need to remove parts. i am hoping the master cylinder arm has came off a common problem but cant find where it is. give up on taking it to a garage at this time of year any advice to check the master cylinder and slave forget the slave thats in the clutch housing only trying to check the clutch actuating rod on the master cylinder Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 21, 2017 Share Posted December 21, 2017 Have you checked the clutch pedal is still attached to the master cylinder? look under the pedal, cant miss it. Quote Link to comment Share on other sites More sharing options...
isetta Posted December 21, 2017 Share Posted December 21, 2017 look up under dashboard at top of clutch pedal. see pic below. the plastic rod that goes into mater cylinder sometimes get detached from the peg on the pedal. This one has been made secure by drilling a hole through the peg and putting a split pin through the hole so the plastic rod can not slide off. 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 22, 2017 Share Posted December 22, 2017 I carry a collet in my toolbox for these! I have done so many of them! I helped someone push a car into the car park at work earlier in the week. I asked him what was up, would you believe 'the clutch pedal just sinks to the floor' lol. Awaiting the case of beer Quote Link to comment Share on other sites More sharing options...
isetta Posted December 22, 2017 Share Posted December 22, 2017 this is the collet thing that does the job. this is the easiest way to fix it if it is that problem. I am not saying buy it from this seller, I ma just showing you what it looks like. It is certainly easier to fit one of these than drilling a hole to put split pin through. I think a star washer could also do the job but probably harder to remove if it needed to be taken off for any reason https://www.ebay.co.uk/itm/FOR-FORD-FIESTA-MK6-FUSION-MAZDA-2-CLUTCH-PEDAL-REPAIR-KIT-CLIP-INC-ALLEN-KEY/332355509519?epid=2202987116&hash=item4d61ee9d0f:g:UtMAAOSwB3tZnqQI 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 22, 2017 Share Posted December 22, 2017 Here is a picture of the collets I use, looks exactly the same as the one posted by Isetta. Quote Link to comment Share on other sites More sharing options...
