Proz Posted March 17, 2018 Share Posted March 17, 2018 As above in this video he puts the rear calipers into maintenance mode. Its in the first 3-4 minutes of the video I assume this will work for our Mondeo MK5's ? I know the car in the vid is a Fusion but they will be similar surely ? A google around doesnt really clear it up ... some saying it does work and some saying it doesnt. Can this be done with Forscan ? Thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted March 17, 2018 Share Posted March 17, 2018 the video is correct and is the same for the mondeo. 1 Quote Link to comment Share on other sites More sharing options...
Proz Posted March 17, 2018 Author Share Posted March 17, 2018 8 minutes ago, iantt said: the video is correct and is the same for the mondeo. That'll make changing the pads and discs simple then .... Quote Link to comment Share on other sites More sharing options...
iantt Posted March 17, 2018 Share Posted March 17, 2018 Set the ignition to ON. Press and hold the brake pedal. Press the EPB switch to release the parking brake. Release the brake pedal and the EPBswitch. Press and hold the accelerator pedal and place the EPB switch to the RELEASE (downward) position. Continue to hold the accelerator pedal and EPB. Set the ignition to OFF then set the ignition to ON within 5 seconds. Continue to hold the accelerator pedal and the EPB switch. 2 1 Quote Link to comment Share on other sites More sharing options...
