How To Change Fog Light Bulbs, Very Simple!
Harvey19
 Share
Hey All,
Just thought I'd do a quick post on how to change the bulbs for your fog lights, Simply follow the headlight change guide on the main forum page to remove your headlight chamber.
Then once you have done this you should be able to see the fog light internals below, now just twist out the bulb holder and replace! Remembering to handle any halogen bulb with gloves as natural body oils will damage or shorten the life of the bulb.
I'll be changing my standard halogens for "Osram Night Breaker Plus" sometime next week so I'll let you know how I get on!
P.s The bulb type is H11
Hope this helps,
Harvey
  • Like 1
Link to comment
No problem! Stumbled across the method whilst messing with the headlights, thought I might as well share :D
Harvey
Link to comment
Or you could do this the intended easy way
-Full lock to the left on steering wheel for the right fog light.
-Full lock to the right on steering wheel for the left fog light.
Remove the 2 screws on the black plastic wheel arch and pull back wheel arch.
There immediately behind the wheel arch are the fog lights, with full ease of access.
HTH
Link to comment
Well if you happen to be changing your headlights like I am then this way is far easier, no !Removed! around needed (excuse the pun)
Link to comment
or do what i did.... drive it up a ramp and get under neath :) probably the harder way tbh but its easy enough... only problem is the washer fluid container gets in the way of one of the fogs and makes it tricky
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
