Sign in to follow this
Followers 0
holiday
Front Passenger Footwell Water Leak
2 posts in this topic
Hi
Having trouble with water leaking into footwell when parked. This fault appears to have occured very recently. Started noticing problem with ice inside of windscreen, then after heavy rain carpet was swimming. Removed trim in side of footwell and water running down cables. Traced to rubber gromets in bulkhead behind fuse box. Cleaned them up and re fitted with silicon grease. Checked pollen filter cover seems OK. Got hose pipe out still leaking. Any other ideas
Hi
hi pall check the gromit were the speeker wires go through to doors i ran a power cable thru this and had same prob
Followers 0
