taxijohn Posted November 13, 2012 Share Posted November 13, 2012 my focus is a 51 plate and overnight has developed a bad smell indside the car the pollen filter was recentley changed and there are no water leaks into the car i dont what else to check any body got any thoughts thanks Quote Link to comment Share on other sites More sharing options...
dezwez Posted November 13, 2012 Share Posted November 13, 2012 screen wash goes bad and smell Quote Link to comment Share on other sites More sharing options...
cuke Posted November 13, 2012 Share Posted November 13, 2012 Hi, you might need to clean your air vents as bacteria will growing in them, that is quite normal. There are several products on the market to perform this with easy to follow instructions, try here for one http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_224996_langId_-1_categoryId_165632 although I can't endorse it as I've not had to do this myself because I rely upon the dealership to do it for me. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 13, 2012 Share Posted November 13, 2012 I'd agree. Aircon units produce a lot of moisture and when this goes stagnant the smell is not pleasant. A good aircon cleaning bomb is very effective. Stick it in the car, switch on the air, set off the can and retire to allow it to do the job. Quote Link to comment Share on other sites More sharing options...
ajt Posted November 13, 2012 Share Posted November 13, 2012 The Halfrauds one is about £12, which I have used in the past. Very effective. Then stumbled upon Dettol Disinfectant spray at Te£co£, twice as much for a quarter of the price. Just need to turn recirc on, and spray plenty into front footwells, aiming up under dash. Works a treat. Quote Link to comment Share on other sites More sharing options...
taxijohn Posted November 15, 2012 Author Share Posted November 15, 2012 thanks for the advice i will try to clean the air vents although the car doesnt have air con and the smell does not get worse when heater is on the smell is there only initially after getting in car but isuppose nose gets used to it thanks all Quote Link to comment Share on other sites More sharing options...
JasonLeake Posted November 28, 2012 Share Posted November 28, 2012 Cat Quote Link to comment Share on other sites More sharing options...
