Hell5200
Door Card Removel
11 posts in this topic
Hi does anyone know how to remove the rear door cards of a 2009 focus. I've found the screw behind the handle trim and gave it a pull and part of it popped off. Any help appreciated
If you have a look at the Focus Guides section, Lenny did a mod of installing a projected ford logo in the door, he did a full strip down of the door, so that would be a good place to look.
Or is this the latest shape Focus?
Hey thanks just looked at that. But the rear door differ to the front ones. :(
I think there are 2 bolts behind the plastic handle/armrest, the cover should pop off with a flat headed screwdriver.
Or maybe reading your initial post again, you may have already found that :-o
The actual door card itself is secured on by retaining clips all around the door which just pull off
Just the screw behind the door handle I found. I tried getting the armrest bit off with a screwdriver but it wouldn't budge. Also the window handle needs to come off. I remember seeing a post here a while ago how to get this off but I can't find it.
Not sure, mine are electric in the rear. Best of luck
I think there should be a small flatblad sized gap in the handle of the window arm. This should pop off with a screwdriver and then the nut ondone to release the handle.
Easiest way to get window winders off is to run the edge of a cloth between the winder and door card to push in the clip then pull the handle off.
