Robblait Posted May 13, 2014 Share Posted May 13, 2014 When i start my car straight away the ac fan comes on, it goes off every now & then but runs all the time even when my ac is on low, the fan is working at full & is very noisy. Ive looked around cant see any obvious signs of fault? Ford focus 2006 Tdci zetec Thanks. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 13, 2014 Share Posted May 13, 2014 is it pointing the vents at the windscreen? Quote Link to comment Share on other sites More sharing options...
Robblait Posted May 13, 2014 Author Share Posted May 13, 2014 It is yea all positions i think I've tried Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Robblait Posted May 13, 2014 Author Share Posted May 13, 2014 Yep been out in the car & it still does it in all positions, doesn't matter if blowing in face, windscreen or floor. Fan still goes on constant & loud. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 14, 2014 Share Posted May 14, 2014 sounds like the motor is stuck, your probably going to have to get access to the rear and see if you can move it manually, if its locked tight, then you will need a new motor. Quote Link to comment Share on other sites More sharing options...
Robblait Posted May 14, 2014 Author Share Posted May 14, 2014 What? The fan is constantly on, how can it be stuck? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 15, 2014 Share Posted May 15, 2014 Ah, so it blows in all directions but never stops being full blast? I may have misunderstood Sent from my MY SAGA C2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Robblait Posted May 15, 2014 Author Share Posted May 15, 2014 Sorry i mean the front fan next to the grill, when ac is on its constantly on full & very loud Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
artscot79 Posted May 15, 2014 Share Posted May 15, 2014 its supposed to be on when the ac is on thats how it works there are 2 speeds to the fan but it should and will run all the time the ac is on Quote Link to comment Share on other sites More sharing options...
