StanH Posted August 25, 2014 Share Posted August 25, 2014 The backlighting on my display is quite adequate and controllable after dark but the illumination is totally inadequate in most daylight situations. Is there any way in which this can be boosted? Stan Quote Link to comment Share on other sites More sharing options...
troy45 Posted August 25, 2014 Share Posted August 25, 2014 As far as I've worked out, with the headlights off all the illuminated bits and pieces are just powered with a 12V supply from inside the bit of kit you're looking at (radio, clocks, heater module etc) - the dimmed feed comes in externally but there's no specific feed for the daytime lighting. When you adjust the dimmer switch to it's max you get pretty much the same voltage to the LED's. Only way to get them brighter would be to change all the SMD's to brighter versions or raise the voltage on them above the power coming from the car - but as there's no isolated circuit for the illumination you'd have to jack up the whole cluster voltage and this would most likely end in tears. Quote Link to comment Share on other sites More sharing options...
StanH Posted August 26, 2014 Author Share Posted August 26, 2014 Thanks - I wouldn't know how to go about getting at the SMDs, let alone changing them, so I guess I'll have to live with it Quote Link to comment Share on other sites More sharing options...
IINexusII Posted August 26, 2014 Share Posted August 26, 2014 are you talking about the display on the dash or the radio? as yours is 2006 i assume you have green led's and the info display on the dash is fine in daylight but the sony radio is not readable in daylight Quote Link to comment Share on other sites More sharing options...
StanH Posted August 26, 2014 Author Share Posted August 26, 2014 It is the dash display, although I find the radio etc. fairly unreadable. Quote Link to comment Share on other sites More sharing options...
