MaxHBurrell Posted August 29, 2014 Share Posted August 29, 2014 Hi, First time poster - I hope you can help me out here! :) My Focus has odd wheels and I'm trying to find out which ones are actually the correct ones! (I think two of them might be from an escort potentially?) Here is a picture of the drivers side front wheel: and here is one of the passenger side front wheel: As you can clearly see, they don't match! This means that the drivers side wheels stick out slightly from the car body and the passenger side ones look sunk in. I'd say by about 10mm for each respectively. My question is: are either of these the correct steel wheels for my 2000 Mk1 1.8 Focus? (its second hand by the way). Many thanks Max Quote Link to comment Share on other sites More sharing options...
madmole Posted August 29, 2014 Share Posted August 29, 2014 It also means the offsets are different. Your car must handle very strangely! as well as being illigal on the road like that I'd swap em round so the wider ones are on the back axle and the narrower on the front. Would improve the handling and make it legal again Are the tyres the same size? Would suggest to me the car was crashed or badly kerbed before and someone just got hold of 2 cheap wheels to repair it Quote Link to comment Share on other sites More sharing options...
MaxHBurrell Posted August 29, 2014 Author Share Posted August 29, 2014 Hi, thanks for the reply! To be honest it doesn't feel any different other cars I have driven, but, I'm very concerned about the legality of it that's for sure! No one really notices it until I point it out, and I didn't notice it for ages! Thanks for the advice on changing them round - I will look into this. The tyres are all 185 65 R14. I'm thinking of replacing all the steelies with some cheap alloys to solve the problem. Do you have any advice on which ones would fit the tyres? (I don't want to lose the tyres as they have very little wear on them). Perhaps some alloys from another ford model? I think you are right about them being kerbed way back in the day. Cheers Quote Link to comment Share on other sites More sharing options...
madmole Posted August 29, 2014 Share Posted August 29, 2014 I'd trawl the local breakers for similar ford and see what they have. Likely to be cheaper that way Your legal if each axle has matching pairs. front rear is not important, although convention has the wider stance at the back Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted August 29, 2014 Share Posted August 29, 2014 Hi max ive just taken off 4 wheels from my mk1 focus zetec the tyres have tread but they were part hust to pass its mot theyre damaged but theyre legal and theyl look abit better than steels mine are 15" let me know if your near Wednesbury you can take a look i dont want alot for them Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
