rgloverd Posted December 26, 2014 Share Posted December 26, 2014 Hi, my high level brake light has stopped working, can I just replace a bulb or is it a matter of replacing the entire light fitting? if so where is the best place to get one from? Thanks,Richard Quote Link to comment Share on other sites More sharing options...
peteraodonnell Posted December 26, 2014 Share Posted December 26, 2014 Richard, you can replace the bulb. Carefully ease out the fitting, there is a video on YouTube it's quite simple really. I got a bulb from my local BMS. Quote Link to comment Share on other sites More sharing options...
peteraodonnell Posted December 26, 2014 Share Posted December 26, 2014 When you open the boot you will see some rubber grommet where the brake light is. You will need a flat blade screwdriver and if you look carefully you will see two metal clips that are fiddly to get off. Once they're off really easy to get back on. Just be careful some times the clips can ping off! Quote Link to comment Share on other sites More sharing options...
MarksST Posted December 26, 2014 Share Posted December 26, 2014 You can't change the bulb on the brake light of a mk7, it's an LED strip. If it's this that is faulty then you need to replace the unit. http://www.fordpartsuk.com/shop/ford_fiesta_high_level_brake_lamp_2008-2010__f_1765700_c_579.htm Quote Link to comment Share on other sites More sharing options...
