jrn1919 Posted February 26, 2015 Share Posted February 26, 2015 Hi no throttle on start up but revs to 2 grand. and i feel the slow return of the of revs isn't correct? any ideas or is it normal thanks even if you think its right or not just say , but would love some advice please this.wmv Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 26, 2015 Share Posted February 26, 2015 Sounds like a throttle issue, possibly the potentimeter? Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 26, 2015 Share Posted February 26, 2015 Not right no should only hit about 1100 briefly then drop down slowly if the cars a mk1 or 1.5 then idle control valve if its news then the above suggestions what IDE say as well Quote Link to comment Share on other sites More sharing options...
jrn1919 Posted February 27, 2015 Author Share Posted February 27, 2015 thanks for the reply's it a 2008 1.8 petrol focus right ive had new throttle body and senor ,now ive also noticed a slight back fire also been updated to all the new software Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 27, 2015 Share Posted February 27, 2015 Backfire suggest overfueling or coil pack was it present before the throttle body was replaced? The idle I believe is controlled by the ecu on the later 1.8 so somethings throwing the readings out on the rear of the throttle body there's a hose going into it try getting someone to rev the engine as you look at the hose if its collapsing that coil be you're culprit also check it for splits. If this has happened after the throttle was changed then it coil be its not been fitted correctly other culprits can be faulty o2 sensors in the exhaust Quote Link to comment Share on other sites More sharing options...
jrn1919 Posted March 2, 2015 Author Share Posted March 2, 2015 hi, sorry for delay backfire is a popping noise not always happening ,and it wasn't present before the throttle body change ive checked the pipes i can see ,but cant find anything wrong there the work was all done at a ford dealer ,they keep saying this is normal for the revs ? i aint to sure about that statement wouldnt the o2 sensor throw up an error code if this was wrong ? thanks Quote Link to comment Share on other sites More sharing options...
