-Dan- Posted March 1, 2015 Share Posted March 1, 2015 Hi all right, got a bit of a fault with my boot, it will unlock with the key but that's is it, the button on the button on the dash does not a lot, and the fob does not either! So anyone else had the same fault? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 1, 2015 Share Posted March 1, 2015 I'd suspect a blown lock solenoid or a damaged wire in the rubber sleeve between the roof and hatch. First check the wiring is intact either by physical inspection or check if power is getting to the lock unit with a voltmeter. Tbh I'd say the wires are the main culprit but this fault can also cause the solenoid to pop. As the solenoid is not a servicable part you would need a replacement one. eBay is a good source. I have a guide to swapping the key barrel over so you can keep all the locks on one key (view link under this post on a PC). I had this problem when I owned a MK1 Focus, the damaged wires shorted over to the third brake light wiring so that the boot popped every time I braked. By the time I sussed it out the lock and rear wiper had both blown. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 1, 2015 Share Posted March 1, 2015 http://pages.ebay.com/link/?nav=item.view&id=361228803830&alt=web Quote Link to comment Share on other sites More sharing options...
-Dan- Posted March 1, 2015 Author Share Posted March 1, 2015 Brilliant this is my job for next weekend thank you for your help Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 1, 2015 Share Posted March 1, 2015 You may well find that more than one wire is damaged (if that turns out to be the cause), and if so the cores get corroded and blackened so would need trimming back to clean core and a patch crimped/soldered in. Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
-Dan- Posted March 4, 2015 Author Share Posted March 4, 2015 Cool cheers for the advice 1 Quote Link to comment Share on other sites More sharing options...
