wbt50 Posted May 19, 2015 Share Posted May 19, 2015 I have just bough a 58 plate fiesta titanium today. I have bonded my phone with the wireless audio system, so I am able to make and receive calls etc. But I can't get it to stream music from my phone, I can't find any option to do that. How exactly do I stream music from phone to the audio system ? Tha ks for any help! Quote Link to comment Share on other sites More sharing options...
jbell Posted May 19, 2015 Share Posted May 19, 2015 Only the "bluetooth high" modules support audio (A2DP). If you don't have USB fitted, chances are you've got a "bluetooth low" module. The module can be swapped but you'll need a willing dealer to change some parameters via IDS. I'll know for sure on the 26th if this works (I've got mine booked in). Basically: Swap module behind glovebox with 8m5t-19c112-AM or later (e.g. 112-AN, AP, etc) Dealer changes - bluetooth handsfree: Select BT/VC Phone Interface + USB Connection - Accessory USB Unit: Select With USB and iPod Function - Update display, bluetooth and audio modules if required. Module is pricy from Ford (£200-300), but you can use a second hand one from eBay (£50-90). If the car model it came from doesn't match your car, you might also need to dealer to change the model via IDS. Quote Link to comment Share on other sites More sharing options...
wbt50 Posted May 19, 2015 Author Share Posted May 19, 2015 I have a usb port. I have also tried playing from the usb port, but again, unsure of where to go. When I select AUX, I just get Line In message and nothing happens. Quote Link to comment Share on other sites More sharing options...
jbell Posted May 19, 2015 Share Posted May 19, 2015 I have a usb port. I have also tried playing from the usb port, but again, unsure of where to go. When I select AUX, I just get Line In message and nothing happens. Was the car advertised as having USB? If you stick your VIN in https://www.etis.ford.com/vehicleSelection.do is USB listed? If you press your voice control button, say "External Device" and then "Help" are AUX, iPod, USB and bluetooth audio listed; or just AUX? Quote Link to comment Share on other sites More sharing options...
mgaking Posted May 19, 2015 Share Posted May 19, 2015 I have a usb port. I have also tried playing from the usb port, but again, unsure of where to go. When I select AUX, I just get Line In message and nothing happens. keep pressing AUX. Should give you line-in; USB; bluetooth options. Quote Link to comment Share on other sites More sharing options...
wbt50 Posted May 20, 2015 Author Share Posted May 20, 2015 keep pressing AUX. Should give you line-in; USB; bluetooth options. All I get is USB, Line in, and Ipod... Quote Link to comment Share on other sites More sharing options...
jbell Posted May 20, 2015 Share Posted May 20, 2015 What about via your voice control as in my last post? Quote Link to comment Share on other sites More sharing options...
mgaking Posted May 20, 2015 Share Posted May 20, 2015 Ipod? Quote Link to comment Share on other sites More sharing options...
jbell Posted May 20, 2015 Share Posted May 20, 2015 There used to be a specific cable for using iPod's - audio via the aux and song info via USB ( the "ford y cable"). Quote Link to comment Share on other sites More sharing options...
wbt50 Posted May 21, 2015 Author Share Posted May 21, 2015 What about via your voice control as in my last post? The only options available was Line in and USB. So I take it that it does not support bluetooth audio streaming ? Quote Link to comment Share on other sites More sharing options...
wbt50 Posted May 21, 2015 Author Share Posted May 21, 2015 Also, I'm unable to play audio via USB from my phone. I guess it's a compatibility issue, I have a Samsung Galaxy S6. Quote Link to comment Share on other sites More sharing options...
jbell Posted May 21, 2015 Share Posted May 21, 2015 http://www.fordownersclub.com/forums/topic/32147-guide-video-how-to-removereseatreset-bluetooth-usb-module-mk7/#entry225358 If you follow that and check the modules part number (underneath the module) we should be able to figure out what's up. It should start with 8m5t Quote Link to comment Share on other sites More sharing options...
