miff Posted August 29, 2015 Share Posted August 29, 2015 hi have a 04 streetka been doing some work on it for mot I think after battery removed and jump start my problem started. I get nothing when I try to start now when I turn ignition on abs & oil lights come on but I don't get ignition or battery light. thanks for any help Quote Link to comment Share on other sites More sharing options...
delboy Posted August 30, 2015 Share Posted August 30, 2015 try a new battery as the old one maybe faulty what work did you carryout on the car ? Quote Link to comment Share on other sites More sharing options...
miff Posted August 30, 2015 Author Share Posted August 30, 2015 the work I carried out for mot was replaced rear shock absorber fixed faulty earth in near side headlight new flexi pipe for the exhaust . I have tried jump starting the car from another I still get nothing checked all the fuses and swapped around some relays. put live straight to starter it turns normally but fuel pump does not come on its like no power is going anywhere Quote Link to comment Share on other sites More sharing options...
Omendata Posted September 8, 2015 Share Posted September 8, 2015 Sounds like user error - if it was working before you fiddled with it then you may have caused the issue yourself - not uncommon i've done it myself - did you find the issue? Relay swapping? Not a good idea! Why not just test the relays with a mutimeter or just plug two 12v sources and listen for the relay click if you dont have test equipment!¬ Quote Link to comment Share on other sites More sharing options...
delboy Posted September 9, 2015 Share Posted September 9, 2015 have you sorted it yet ? Quote Link to comment Share on other sites More sharing options...
miff Posted September 14, 2015 Author Share Posted September 14, 2015 hi thanks for the replies yes I sorted it even though the fuses tested ok with a multimeter the ecc fuse had a bad connection just pulled it out and replaced it and everything working again. cheers Quote Link to comment Share on other sites More sharing options...
delboy Posted September 15, 2015 Share Posted September 15, 2015 happy motoring !! Quote Link to comment Share on other sites More sharing options...
