mrbelly Posted November 22, 2015 Share Posted November 22, 2015 Hello, Last week my right headlight stopped working but the side light was still fine. Today the other one has gone so all I have is side lights, or whatever the lower power ones are called. If I flash someone I still get the bright light to flash them with though. Does this suggest a wiring problem or a fuse maybe? Cheers for any help. 1 Quote Link to comment Share on other sites More sharing options...
SeanW Posted November 22, 2015 Share Posted November 22, 2015 Sidelights are the dim little lights Dipped beam lights are the ones most commonly used High/full beams are the bright ones I'd be inclined to say the bulbs have blown. It isn't uncommon for them to go in pairs. Take them out and have a look at the filament. Replacement bulbs can be bought for a couple of quid a piece. (Or about £15 for a pair of Osram Nightbreaker Unlimited lol) 2 Quote Link to comment Share on other sites More sharing options...
Lenny Posted November 22, 2015 Share Posted November 22, 2015 bulbs should always be replaced in pairs, When one blows; the other is never far behind. I recommend osram NightBreaker H7 dipped beam And Osram NightBreaker H1 for high beam He see dipped beam And high beam are separate bulbs on the focus 2 Quote Link to comment Share on other sites More sharing options...
mrbelly Posted November 22, 2015 Author Share Posted November 22, 2015 Cheers both of you. I wasn't in the mood for some random electrical problem especially in the winter. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted November 22, 2015 Share Posted November 22, 2015 Cheers both of you. I wasn't in the mood for some random electrical problem especially in the winter.happy to help, For optimum results I recommend having headlight alignment done after bulb change, bulbs can be fitted upside down; I'm guilty of this myself was picked up by garage on alignment. Spring coil inside bulb should be on bottom when fitting 😕 I purchase osram on eBay and bring to local garage for fitting and alignment 👍 1 Quote Link to comment Share on other sites More sharing options...
mrbelly Posted November 22, 2015 Author Share Posted November 22, 2015 Well if they can be fitted upside down I think that's the way I'd end up doing them. 1 Quote Link to comment Share on other sites More sharing options...
