Brownie84 Posted June 24, 2017 Share Posted June 24, 2017 Is it possible to swap the stereo for the touch screen On my 2015 Ford Focus please seen them on eBay for £250 any help will be great thanks Quote Link to comment Share on other sites More sharing options...
JW1982 Posted June 25, 2017 Share Posted June 25, 2017 Yes it is possible to change the standard audio system with 3.5 Inch monochrome display or 4.2 Inch full color display for the SYNC 2 or SYNC 3 system with 8 Inch touchscreen. However the wiring is also different. Next to the complete SYNC 2 or SYNC 3 system you also need the complete dashboard wiring harness or you have to modify the existing wiring harness yourself. If the car currently has the SYNC 1.1 system the wiring issue can be solved quite easily by using an adapter harness that connects between the SYNC 1.1 APIM connector and the SYNC 2 / SYNC 3 APIM. This adapter harness does not exist so you have to make it yourself. 1 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 25, 2017 Share Posted June 25, 2017 Is there any difference in (or improvement of) the selection of commands available between sync 1.1 (which is what I think I have) and 2+? What dash parts are needed to accommodate the touchscreen? Actually, I think I understand - its the entire centre dash that changes? http://www.ebay.co.uk/itm/FORD-FOCUS-ST-OEM-SONY-MICROSOFT-SYNC-TOUCHSCREEN-NAVIGATION-INFOTAINMENT-RADIO-/282252854840?epid=721274553&hash=item41b794c638:g:YEAAAOSwKOJYJkS8 And I assume a change to the CCC has to be made? Also, have a look at this on eBay: http://www.ebay.co.uk/itm/Ford-Sync-2-/201961770658?hash=item2f05dc0ea2:g:ATkAAOSwyWZZS5i9 Quote Link to comment Share on other sites More sharing options...
Brownie84 Posted June 25, 2017 Author Share Posted June 25, 2017 Thanks for the reply how much would it cost for someone to do that for me Quote Link to comment Share on other sites More sharing options...
