Leezer Posted April 30, 2018 Share Posted April 30, 2018 Haven't posted in ages... So I've been over a few potholes lately, been noticing a bit of squeak over bumps and the ride is definitely rougher. Is it worth leaving in to get checked with ford now or should I wait tile the next service in 6 months? Also do Ford charge for just checking out what the issues might be? I know no one can predict what the issue is but if it is suspension related could it be an expensive fix? Thanks. Quote Link to comment Share on other sites More sharing options...
jbell Posted April 30, 2018 Share Posted April 30, 2018 I've been meaning to check mine - supposedly this can be the sway bar/anti roll bushing. Ford would likely charge labour rate to investigate which can differ per garage. Probably upwards of £70/hour. Quote Link to comment Share on other sites More sharing options...
Leezer Posted May 5, 2018 Author Share Posted May 5, 2018 What sort of symptoms are you getting? I'm noticed passenger side creaking over bumps and ride general feeling a bit rougher and slightly more roll when turning. Part of me thinks it might be just in my head but think I'm gonna leave it in to make sure. Any progress your end? Quote Link to comment Share on other sites More sharing options...
jbell Posted May 6, 2018 Share Posted May 6, 2018 8 hours ago, Leezer said: What sort of symptoms are you getting? I'm noticed passenger side creaking over bumps and ride general feeling a bit rougher and slightly more roll when turning. Part of me thinks it might be just in my head but think I'm gonna leave it in to make sure. Any progress your end? Creaking with going over speed bumps and when turning while braking at low speeds. Not had a look yet. I'd read somewhere on here a bit of silicone spray might help. Quote Link to comment Share on other sites More sharing options...
TDR|XTC Posted May 6, 2018 Share Posted May 6, 2018 Hi Leezer! If those potholes were pretty big, check to see if the shocks leak. Also inspect the coil springs if you're there. And try to see if the anti roll bar links are moving, as they should be rock solid . Quote Link to comment Share on other sites More sharing options...
