DickP Posted June 9, 2018 Share Posted June 9, 2018 Hi, First post here! I am considering getting a Focus Estate, possibly the Mk3 with the 1.6 TDCI engine. My query is what lifespan do the DPF typically have on these cars? Is there an easy way to find out how full they are and when it would require replacement? What is the typical cost of the replacement DPF? Thanks! Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted June 9, 2018 Share Posted June 9, 2018 A well maintained one should last at least 100,000 miles, but one failed on a van at work after 6000 as they literally drive 2 miles at a time. Ended up costing the company around £1800 to fix. We get charged stupid amounts though as it's a big company so nobody will say anything or shop around. I'm not sure what DPF info Forscan gives you, but I'm sure someone else on here will know. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted June 10, 2018 Share Posted June 10, 2018 I do a high mileage and have never replaced one, my last 3 mondeos did over 175k no DPF problems apart from split sensor pipes, the shortest journey I do is 23 miles and very litt town driving 1 Quote Link to comment Share on other sites More sharing options...
Tasape Posted June 10, 2018 Share Posted June 10, 2018 just remember to put some DPF cleaner in every 3000 miles or so redex do one it cleans the dpf and injectors Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 10, 2018 Share Posted June 10, 2018 The Mk3 Focus uses a coated DPF which is far more effective and reliable than the old Eolys style used in most Mk2s and a lot of PSA vehicles. It should last well over 100k if driven normally, they don't even mind a bit of town as long as the majority are longer trips. Forscan does show the soot loading in the DPF on these but high soot loading isn't necessarily a sign of needing replacement, just that it needs to regenerate on a long run. There is no way to determine the exact lifespan of each individual DPF, too many variables. I wouldn't personally recommend running any sort of fuel or DPF cleaner through these but opinions will vary there. Price of an aftermarket DPF for these is £350+. Takes a few hours labour (so maybe £200 depending on labour rates). Genuine DPF is more like £800! 2 1 Quote Link to comment Share on other sites More sharing options...
DickP Posted June 10, 2018 Author Share Posted June 10, 2018 Hi Thanks for the replies, very useful. That'a also good news TomsFocus on the cost front, sounds like they're not as expensive as they were once made out to be. Thanks, Quote Link to comment Share on other sites More sharing options...
pragmatix Posted June 10, 2018 Share Posted June 10, 2018 8 hours ago, Tasape said: just remember to put some DPF cleaner in every 3000 miles or so redex do one it cleans the dpf and injectors Snake oil 1 Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted June 10, 2018 Share Posted June 10, 2018 We run our 2014 cmax 1.6 tdci on Shell v power which helps keep soot levels lower. Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted June 11, 2018 Share Posted June 11, 2018 14 hours ago, JONATHAN_11_80 said: We run our 2014 cmax 1.6 tdci on shell v power which helps keep soot levels lower. Strange, I found that V Power causes my cause to start regeneration more frequently! Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted August 5, 2018 Share Posted August 5, 2018 Not noticed regular regeneration while running on v power to be honest. Ours doesn't like bp ultimate. Quote Link to comment Share on other sites More sharing options...
