Turbo1 Posted June 10, 2018 Share Posted June 10, 2018 2014 - AC light on , regassed, fuse seems ok, slight noise when turning on/off (presume compressor working), fan works. Owned for 6months never worked. Any ideas??? Quote Link to comment Share on other sites More sharing options...
540itouring Posted June 10, 2018 Share Posted June 10, 2018 If it had gas before the recharge we take it has not worked after I would need to know what the static pressures are and then the hi and low pressures with AC switched on with AC if the Compressor clutch is spinning you need to know the pressures so ask the garage that recharged it last ? Quote Link to comment Share on other sites More sharing options...
Turbo1 Posted June 10, 2018 Author Share Posted June 10, 2018 where is the compressor on the mk7 Quote Link to comment Share on other sites More sharing options...
540itouring Posted June 10, 2018 Share Posted June 10, 2018 on the ecoboost its on the off side lower front but you will see two large hose / pipes going to it what every engine you have Quote Link to comment Share on other sites More sharing options...
Turbo1 Posted June 10, 2018 Author Share Posted June 10, 2018 Cheers....will have to find out the pressures from the mobile ac service used today....what you thinking? Quote Link to comment Share on other sites More sharing options...
540itouring Posted June 10, 2018 Share Posted June 10, 2018 I will think about it when you give me the pressures as that is where you start with ac that will tell me what the system is doing if any this is working etc Quote Link to comment Share on other sites More sharing options...
