F0CUE Posted February 3, 2019 Share Posted February 3, 2019 Hi I went and bought just 2 litres of transmission oil and found it takes 2.3 to be full for my ib5 version will a lack of 300ml cause any issues or is it safer to wait on more? 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 3, 2019 Share Posted February 3, 2019 should be but I would fill it as soon as Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 3, 2019 Author Share Posted February 3, 2019 Thanks it's just cos I got specific oil and I need this done due to leaks in the selector which I'm going to replace and would mean waiting on more. I'm worried about mixing different brands as have been reading it's not the best idea. Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 3, 2019 Share Posted February 3, 2019 stick with the same brand and spec ☺️ 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted February 3, 2019 Share Posted February 3, 2019 Be aware that this type of IB5 gearbox does not have a drain plug because these gearboxes are filled for live and there is no oil change interval. The drain plug on the later type of IB5 gearbox was introduced on the Focus MK3. To drain the older IB5 gearboxes completely you have to take a driveshaft out of the gearbox. The correct oil level of the IB5 gearbox is as follows: * IB5 manual transmission (5-10 mm below lower edge of check hole) 1 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 3, 2019 Author Share Posted February 3, 2019 2 hours ago, JW1982 said: Be aware that this type of IB5 gearbox does not have a drain plug because these gearboxes are filled for live and there is no oil change interval. The drain plug on the later type of IB5 gearbox was introduced on the Focus MK3. To drain the older IB5 gearboxes completely you have to take a driveshaft out of the gearbox. The correct oil level of the IB5 gearbox is as follows: * IB5 manual transmission (5-10 mm below lower edge of check hole) Thanks so I may be having to pull the drive shaft then because I don't want to mix oils. I imagined pulling the old selector seal would just empty it out. It's weird cos I seen a video of somebody taking a bolt out further down from the filler and it all drained out. The bolt on the bottom of this pic. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted February 3, 2019 Share Posted February 3, 2019 That is not just a bolt but the locking bolt of the selector shaft. I have seen before that people who used this bolt to drain the gearbox ended up disassembling the gearbox because they could not get the bolt back in because parts of the selector mechanism came loose inside the gearbox. Personally I would not use this locking bolt to drain the gearbox. Ford does not prescribe any method to drain the gearbox because it is considered to be filled for life. However my personal experience is that the easiest way to drain the IB5 box without any risk is by removing a driveshaft. It is good practise to also replace the particular driveshaft seal because there is a huge chance that the seal will start leaking after disassembly/assembly of the driveshaft. 2 1 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 3, 2019 Author Share Posted February 3, 2019 23 minutes ago, JW1982 said: That is not just a bolt but the locking bolt of the selector shaft. I have seen before that people who used this bolt to drain the gearbox ended up disassembling the gearbox because they could not get the bolt back in because parts of the selector mechanism came loose inside the gearbox. Personally I would not use this locking bolt to drain the gearbox. Ford does not prescribe any method to drain the gearbox because it is considered to be filled for life. However my personal experience is that the easiest way to drain the IB5 box without any risk is by removing a driveshaft. It is good practise to also replace the particular driveshaft seal because there is a huge chance that the seal will start leaking after disassembly/assembly of the driveshaft. Well thank God you said that or I would if went ahead and done it that way. I might just try a Syphon tube. Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 7, 2019 Author Share Posted February 7, 2019 Done the selector seal and drained and filled up today was some learning curve. Now I have shifts like butter and no crunch in reverse and no whine slowing down so pleased with myself 😁 1 Quote Link to comment Share on other sites More sharing options...
FordFocus3 Posted June 27, 2020 Share Posted June 27, 2020 Hey guys! I have the ib5/B5A gearbox with my 1.6 Ti-VCT Sigma engine. Does this version have a drain plug or is it the drain/fill plug that needs to be filled to 5mm under the plug hole? Cheers! Quote Link to comment Share on other sites More sharing options...
FordFocus3 Posted June 27, 2020 Share Posted June 27, 2020 Car is a Mk3 2014 Focus :) Quote Link to comment Share on other sites More sharing options...
Theitking Posted May 25 Share Posted May 25 I just drained the oil using the selector shaft locking bolt. Refitted the bolt with no problems. Refilled with oil when the car was level and box only took 2 litres of oil. Tightened everything up, dropped the car down and drove it for about 2 miles. Car drives fine and gear changes are smoother than before. Why could I only put 2 litres of oil back in? Quote Link to comment Share on other sites More sharing options...
rd457 Posted May 25 Share Posted May 25 2 hours ago, Theitking said: I just drained the oil using the selector shaft locking bolt. Refitted the bolt with no problems. Refilled with oil when the car was level and box only took 2 litres of oil. Tightened everything up, dropped the car down and drove it for about 2 miles. Car drives fine and gear changes are smoother than before. Why could I only put 2 litres of oil back in? Why do you assume it should take more? For that matter why do you assume 2 litres is not too much? The person who created this thread has a 2014 Focus according to their profile, which would be a Mk3. Let's presuming that's the same vehicle they had when they created this thread in 2019. You, according to your profile, have a Mk2 Focus. As noted above there are slight differences between the two. Given there are some differences why would you assume the amount of fluid it takes is the same. Maybe it isn't. Furthermore since the gearbox you have doesn't have a proper drain plug, you're not necessarily going to have gotten out all of the old fluid. What you should have done is captured the old fluid, measured how much you took out, and put back in an identical amount. 2 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 25 Share Posted May 25 Gearbox maximum oil capacity from being totally empty is 2.3 Litre but it is unlikely that you could fully drain the box due to the lack of drain plug and the internal casting of the housing. 1 Quote Link to comment Share on other sites More sharing options...
Botus Posted May 25 Share Posted May 25 comma site 2.3ltr MVMTF Plus 75W-90 Fully Synthetic Recommended by Comma for applications requiring any of the following: Recommended by Comma for certain Ford, Vauxhall, Mazda, Volvo & VAG Group applications and generally where a 75W-90, API GL-4 oil is specified. Suitable for use where the following specifications are called for:, API GL-4 (75W-85), API GL-4 synthetic (75W-85 & 75W-90), BMW MTF LT-4, Fiat 9.55550-MZ1, Ford WSD-M2C200-B, Ford WSD-M2C200-C, GM 1940182, GM 1940764, GM 1940768, Nissan MT-XZ Sports & Off-Road Vehicles, Volkswagen G 50, Volvo 97309, Product Features: ● Fully synthetic manual transmission fluid with excellent bearing and gear protection and proven synchroniser performance ● Good low temperature performance ● Excellent cleanliness ● Robust corrosion protection Quote Link to comment Share on other sites More sharing options...
F0CUE Posted May 26 Author Share Posted May 26 On 5/25/2024 at 4:03 PM, rd457 said: Why do you assume it should take more? For that matter why do you assume 2 litres is not too much? The person who created this thread has a 2014 Focus according to their profile, which would be a Mk3. Let's presuming that's the same vehicle they had when they created this thread in 2019. You, according to your profile, have a Mk2 Focus. As noted above there are slight differences between the two. Given there are some differences why would you assume the amount of fluid it takes is the same. Maybe it isn't. Furthermore since the gearbox you have doesn't have a proper drain plug, you're not necessarily going to have gotten out all of the old fluid. What you should have done is captured the old fluid, measured how much you took out, and put back in an identical amount. It was my MK2 when I posted that. Quote Link to comment Share on other sites More sharing options...
