xcd Posted February 13, 2019 Share Posted February 13, 2019 Hi, I've bought some DRL's which I'm hopefully fitting at the weekend, the standard plastic triangle ones (sadly glossy plastic not stock like matt). I've managed to find some that go half brightness with the headlights although it took a while as a lot either didn't dim or go a chav blue instead. Anyway, it looks easy enough to install (fuse tap)聽splicing with the headlight wire so they dim when on, is there something I can instead do it to so they dim with either the sidelights or the headlights? I'd rather they dim with either to avoid problems but I presume they are on different wires in the headlight unit so I'm not sure where the best place to do it from is. Thanks. Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 13, 2019 Share Posted February 13, 2019 I did mine on the side lights wire and they dim on both 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted February 13, 2019 Share Posted February 13, 2019 Beat me to it Del, sidelight wire will dim at both settings 2 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 13, 2019 Share Posted February 13, 2019 32 minutes ago, Jonro2009 said: Beat me to it Del, sidelight wire will dim at both settings that's what I thought聽馃槉 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 13, 2019 Share Posted February 13, 2019 So guess the same principle would work on the MK2? As mines is spliced into the headlight to dim.聽 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 13, 2019 Share Posted February 13, 2019 2 minutes ago, F0CUE said: So guess the same principle would work on the MK2? As mines is spliced into the headlight to dim.聽 yes聽 馃槉 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 13, 2019 Share Posted February 13, 2019 Yeh of course as they are both on when the headlights are on duh @ me lol聽 Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 13, 2019 Share Posted February 13, 2019 2 minutes ago, F0CUE said: Yeh of course as they are both on when the headlights are on duh @ me lol聽 馃槉 Quote Link to comment Share on other sites More sharing options...
xcd Posted February 15, 2019 Author Share Posted February 15, 2019 Thanks, so final question, what colour is the sidelight wire, I did look at the wiring diagram where I presume it is 'Pos' but I couldn't see the colours just long values. Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 15, 2019 Share Posted February 15, 2019 Pins聽5 = Grey/Brown (GY/BN) = High beam 7 = Black/Yellow (BK/YE) = Ground聽 8 = Blue/Green (BU/GN) = Turn Signal 聽10 = Brown/Blue (BN/BU) = Low beam聽 12 = Yellow/Blue (YE/BU) = Position light 1 Quote Link to comment Share on other sites More sharing options...
