Jollyandy Posted March 12, 2019 Share Posted March 12, 2019 Hi everyone, how do you get into the ‘secret’ test menu on the Mk8? Tried holding the OK button whilst turning on the ignition/press start button, but the old way doesn’t work. If anyone knows...Sorry if it’s been asked already. Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
iantt Posted March 12, 2019 Share Posted March 12, 2019 It should work. It's the ok button on the right of steering wheel.press and hold ok button , switch ign on and keep ok button pressed for 5-8seconds until the "test" or "gauge sweep" shows. 2 Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted March 12, 2019 Author Share Posted March 12, 2019 It should work. It's the ok button on the right of steering wheel.press and hold ok button , switch ign on and keep ok button pressed for 5-8seconds until the "test" or "gauge sweep" shows.Thanks Ian, I’ll give it another try.Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
iantt Posted March 12, 2019 Share Posted March 12, 2019 Just now, Jollyandy said: Thanks Ian, I’ll give it another try. Sent from my iPad using Tapatalk Pro I'm going on the info I have, I I remember I will have a go also the next fiesta I see. 1 Quote Link to comment Share on other sites More sharing options...
lst Posted March 13, 2019 Share Posted March 13, 2019 found a video explaining it > 2 Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted March 13, 2019 Author Share Posted March 13, 2019 found a video explaining it > Brilliant, many thanks got as far as the ‘ET’ part and thought that was all it did. [emoji1303][emoji3]Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
iantt Posted March 13, 2019 Share Posted March 13, 2019 It works . 2 Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted March 13, 2019 Share Posted March 13, 2019 Interesting! Before I start tinkering with this is it possible to inadvertently or deliberately alter any settings when in there? Quote Link to comment Share on other sites More sharing options...
DG97 Posted March 13, 2019 Share Posted March 13, 2019 2 minutes ago, Eric Bloodaxe said: Interesting! Before I start tinkering with this is it possible to inadvertently or deliberately alter any settings when in there? I've had a bit of a play around with it before, i'd say it's highly unlikely to change anything by accident 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted March 13, 2019 Share Posted March 13, 2019 57 minutes ago, Eric Bloodaxe said: Interesting! Before I start tinkering with this is it possible to inadvertently or deliberately alter any settings when in there? Nope 1 Quote Link to comment Share on other sites More sharing options...
tef89 Posted March 13, 2019 Share Posted March 13, 2019 3 hours ago, iantt said: It works . That's the way I want it to look ALL the time 😁 Quote Link to comment Share on other sites More sharing options...
Jonson Posted March 13, 2019 Share Posted March 13, 2019 Is there anything in there that is worth changing? Quote Link to comment Share on other sites More sharing options...
