jpgk82 Posted May 30, 2019 Share Posted May 30, 2019 Have a focus 3 weeks and twice been into garage under warranty There is a noise from the engine bay and the second time I was told its the fan belt and was changed It's still there, like a whopping noise, ill try and post video out audio when I'm home Anyone experience this? Audio https://my.pcloud.com/publink/show?code=XZUlsA7ZtYG6qV0Wr74mM8LOhRD1GRIfGvGk https://my.pcloud.com/publink/show?code=XZRdsA7ZiXLuBIbKXBuvhh6rSzHHP0DkSMXk Quote Link to comment Share on other sites More sharing options...
F0CUE Posted May 30, 2019 Share Posted May 30, 2019 What engine is it petrol or diesel? Quote Link to comment Share on other sites More sharing options...
jpgk82 Posted May 30, 2019 Author Share Posted May 30, 2019 32 minutes ago, F0CUE said: What engine is it petrol or diesel? 1.6 Diesel I know there's a tick off diesel but this is that and whoop whoop whoop noise Quote Link to comment Share on other sites More sharing options...
isetta Posted May 30, 2019 Share Posted May 30, 2019 I had a 1.6 tdci which made a strange noise after I replaced the timing belt. I took the top section timing belt cover off and could see that at certain rpm the belt was vibrating a lot on it’s downward run from top to bottom. I slackened off the tensioner a tad and it was fine after that. You could try removing that upper cover and see what’s going on. 3 Quote Link to comment Share on other sites More sharing options...
jpgk82 Posted May 30, 2019 Author Share Posted May 30, 2019 6 minutes ago, isetta said: I had a 1.6 tdci which made a strange noise after I replaced the timing belt. I took the top section timing belt cover off and could see that at certain rpm the belt was vibrating a lot on it’s downward run from top to bottom. I slackened off the tensioner a tad and it was fine after that. You could try removing that upper cover and see what’s going on. It's under warranty for about two more months so I'll go back to garage so. At first go they adjusted it, pushed on the second and changed the belt Thanks for confirming there can be a noise and I'm not hearing things Quote Link to comment Share on other sites More sharing options...
