RyyLaw Posted June 20, 2019 Share Posted June 20, 2019 Firstly, apologies if this is in the wrong place, really do not know how to use this forum This is probably reaching a bit but does anybody know the size/type of nut used to secure the door mirror on a Fiesta mk7.5? Ling story short, I dropped the nut into the Shell of the door whilst trying to remove it and cannot for the life of me retrieve it. The mirror is now duct聽taped to the door until I can get a replacement nut that actually fits 聽馃檭 聽 Ryan Quote Link to comment Share on other sites More sharing options...
mozz Posted June 20, 2019 Share Posted June 20, 2019 Your local garage will sort it for you, i'd have thought. Quote Link to comment Share on other sites More sharing options...
RyyLaw Posted June 20, 2019 Author Share Posted June 20, 2019 Hadn鈥檛 even thought of that, I鈥檒l have to call into my local on the way to work in the morning Thanks 聽馃憤馃徎 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted June 20, 2019 Share Posted June 20, 2019 You can buy the official Ford nut聽here for 82p plus 拢4.50 delivery (so probably not worth it). You could go to Ford and quote聽4460546 and see how much it costs from them directly (saves delivery cost at least) Alternatively source an M8 nylock and use a washer. These should be dime a dozen. 1 Quote Link to comment Share on other sites More sharing options...
DG97 Posted June 20, 2019 Share Posted June 20, 2019 I don鈥檛 know the answer but as a tip, maybe look at the other side and compare to find the same size with whatever you may have lying around at home Quote Link to comment Share on other sites More sharing options...
RyyLaw Posted June 20, 2019 Author Share Posted June 20, 2019 3 minutes ago, Luke4efc said: You can buy the official Ford nut聽here for 82p plus 拢4.50 delivery (so probably not worth it). Alternatively source an M8 nylock and use a washer. These should be dime a dozen. Perfect!! Thanks mate! I work for a undercarriage wholesaler so I鈥檒l see if we have anything at work now I know the size Quote Link to comment Share on other sites More sharing options...
RyyLaw Posted June 20, 2019 Author Share Posted June 20, 2019 4 minutes ago, DG97 said: I don鈥檛 know the answer but as a tip, maybe look at the other side and compare to find the same size with whatever you may have lying around at home I did think about that but didn鈥檛 trust myself to not drop that one too 馃槵 Quote Link to comment Share on other sites More sharing options...
DG97 Posted June 20, 2019 Share Posted June 20, 2019 26 minutes ago, RyyLaw said: I did think about that but didn鈥檛 trust myself to not drop that one too 馃槵 Had similar trust issues with myself before haha looks like luke4efc has sorted you out with the size though!聽 Quote Link to comment Share on other sites More sharing options...
