Door Dividers?
Hi all,
Looking to take off the grey panels that are between the front and rear windows, surrounding wing mirrors and by the back door, to potentially carbon wrap.
Not entirely sure what they are called, and how to get them off (and if I should even attempt it!)
Any advice would be appreciated.
Hi Richard
Usually they are held on by clips so you will need a set of plastic trim removal tools, it has been know for some to have been put on with adhesive, if this is the case use fishing line in a sawing motion working your way down, protect you paint work in either method. That triangular one in front of the door mirrors is held on with Screws/bolts, that are accessed by prising the top door speaker out with a trim removal lever.
3 hours ago, eddie eastwood said:
Hi Richard
Many thanks Eddie, appreciate the reply.
Will give that a try once I’ve got the bits and pieces, hopefully I won’t snap anything!! 😂
