Zico Posted August 4, 2019 Share Posted August 4, 2019 Any of you know if this is the correct size Gold magnetic sump plug? I found this via various Ford forums as being the apparent correct size: https://www.opieoils.co.uk/p-83813-gold-plug-ap08-magnetic-oil-drain-sump-plug-ap-08-14mm-thread-diameter-15-thread-pitch.aspx Going through the lookup list on the Opie website gives the following different size: https://www.opieoils.co.uk/p-84125-gold-plug-ap04-magnetic-oil-drain-sump-plug-ap-04-thread-diameter-12mm-thread-pitch-175.aspx @Willy @TimST2 @MarksST do any of you have a Gold sump plug or know the correct size? Quote Link to comment Share on other sites More sharing options...
Willy Posted August 4, 2019 Share Posted August 4, 2019 M14 x 1.5 is the thread pattern. 1 Quote Link to comment Share on other sites More sharing options...
Zico Posted August 4, 2019 Author Share Posted August 4, 2019 Thanks @Willy. AP08 it is. Quote Link to comment Share on other sites More sharing options...
