Hallard123 Posted August 10, 2019 Share Posted August 10, 2019 I have recently purchased a ford fiesta zetec 2011-2017 range, and so far it's great, apart from one thing. The in car radio system doesn't start up or turn off upon putting in, or taking out, the keys in the ignition and needs to be switched on off manually. I have tried searching for any settings on the radio to see if it's a simple case of turning a setting from manual to auto, but no luck yet. For clarification the system once turned on/off appears to work normally, I just don't want to forget to turn it off one day and drain the battery. Any advice? Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted August 10, 2019 Share Posted August 10, 2019 The radio turns off after 20 mins or until you open a door. Once you turn it off with the button, it wont then turn back on with the ignition, you have to press the button again. When you next use the car, dont turn the radio off and open a door to make sure it goes off. When you then start the engine the radio will turn on as normal. 1 Quote Link to comment Share on other sites More sharing options...
Hallard123 Posted August 10, 2019 Author Share Posted August 10, 2019 Yeah this worked, thanks for the quick reply. had a feeling I was missing a trick somewhere. Quote Link to comment Share on other sites More sharing options...
