Sync3 update to version 3.4
Hi everybody
Is this method available for Australia and New Zealand ?
  • Replies 547
  • Views 521.8k
  • Luke_Anderson
    Luke_Anderson
    So today I decided to start completely afresh. I re-downloaded all the files from different sources. Formatted 2 different USB’s ( slowly not the quick way ) re-installed the updated firmware to the a
  • Successfully updated to 3.4_19101 using the cyanlabs guide and files. Still have the ST Ford Performace splash screen. Thanks for your help @matt77303 & @vibeone   All I have to do now is g
  • Jury is still out on that one, Clive.  Alex reckons it was pretty buggy, but Tezza and I have not seen the same bugs - Tezza from the start, me after flashing Tezza's files.  I'm happy to report back
On 1/21/2020 at 9:19 PM, Mqrko said:
Hi everybody
working on it 🙂
Hello All,,
I tried many times to download middle east maps with no luck,, now i have v 3.4 19274
Is their anyway to download the Middle east maps,, and should i delete the previous files ??
Really appreciate your help.
5 hours ago, Omran Alabbadi said:
Hello All,,
i can prob sort this, but i'm not sure when, i'm currently re-writing my guide to be more "universal"
FYI guys, if you have the installation in progress error it's likely due to installing in Fat32 not exFAT i have just re-installed with exFAT and i don't get this message any more.
I did too, no message anymore 😃
do you have forscan or ucds? i still have the DTC for "initial configuration not complete" but i don't really care as it's not a visible message on startup any more.
On 1/24/2020 at 6:28 PM, Omran Alabbadi said:
Hello All,,
Can you provide me bezel diagnostics apim ivsu versions (google it)
Hi everybody
I dont suppose anyone here (from the UK and close to SHEFFIELD) would mind doing the APIM upgrade for me, ive already update from sync 3.0 to 3.4.
I WILL NOT HOLD YOU RESPONSIBLE FOR ANY DAMAGE OR LOSS OF USE OF SYSTEM
I was going to attempt myself but can only seem to find NA versions of VBF files and i was going to use Forscan beta but have heard UCMS or whatever it is is better.
thank you
thank you
Literally message tezza he's based right near there 😉 he did mine before I got ucds my self
thank you
Were are you Ryan  ?
Right just to clear things up I’ve followed the guide. And got my files ready. I’m on the latest build of 3.0
once I reformat I can never go back to 3.0 is that because it’s formatted differently?
i only want to skip through all presets is this possible on 3.3 can anyone confirm as I’d just update to 3.3 if that’s the case
APIM QUESTION:
Can I put the APIM <> JK2T-14G371-FCC met softwareversie GB5T-14F374-DG from a recent Fiesta (2018)
In a Ford Focus from 2017 also with Sync3 and is than Sync3 version 3.4 complete working (LOGO/etc/..) ??  (no update necessary for the APIM unit  !!)
Thanks very much   <>   Cees
Hi everybody
I have a potential file for this but i need your IVSU's please follow step 0 in my guide.
Hi everybody
now added to the website 🙂
Why have you linked to my website that is mentioned in the first post lol but thanks anyway lol
Didn't see your initial post.[emoji2955]
Just found the site after a search and thought it would be beneficial.
Right I’m going for it this weekend 😂  currently on 3.0
just to clarify. The lowest I can go back to is 3.3 ? Why not 3.0 @Fma965 any input? I’ve downloaded your files from your site
another thing does sync voice work on 3.4 the one in my new van won’t work without a phone connected and then it’s only Siri find it odd.
The leaked tool which puts the unit in "factory" mode formats the APIM storage and re-partitions it for 3.2+ Sync.
Sync 3.0 uses a different partition layout so they won't be able to load when running the tool again.
A Sync 3.0 format tool has not been leaked, so once formatted, you can only load 3.2+.
Thanks @alexp999 thought that was the case.
What about voice commands ?
On 1/28/2020 at 8:50 PM, Tezza said:
Were are you Ryan  ?
Sorry mate not checked on here for a bit, I’m at Lowedges, Sheffield. Close to you?
I've just done this procedure on my 2018 Transit Custom with swapped out APIM - I thought it was all screwed up after the last update, but hadn't restarted/let the unit enough time to fully switch off. Having left the van for 10 minutes, switched on and all was well, 3.4 and F8 maps. Very happy 🙂
Done the initial update. Disappointed to not be able to switch through the preset banks without swiping the screen.  The sync in my work van can do this though steering wheel.
@Tezza the files you’ve named to update firmware of the APIM are these types of files specific to certain models or will I be good to use those. ?
