Sign in to follow this
gravey11
Engine service now, fuel cut off event
Hi.
ive got a 2016 Ford kuga that states engine service now at ignition. The car runs fine but it’s a bit of an annoyance.
There are 2 FTC codes still current and stating that 1. ‘fuel cutoff event’ and 2. ‘Fuel pump module b control circuit low’ which I assume is a result of the cutoff event.
Crash data has been reset etc and as mentioned the car runs fine. There’s no physical switch on these now as far as I know.
does anyone have any idea how to clear this or what to check?
thanks.
Forscan will clear the codes its a free download and you will need a modified elm connector
https://forscan.org/home.html
https://tunnelrat-electronics.fwscart.com Cheaper ones are available  but not worth it.
oh and a laptop. Limited function on a phone.
I’m using forscan to get the current codes but it still won’t clear as a standard dts clear and I’ve tried doing a crash reset but it states there’s no crash to reset. I didn’t know I could do this so sent the airbag module away to be reset but it’s back in now.
do you know of another operation I need to run in forscan?
thanks.
  Only 75 emoji are allowed.
