Xkalavous Posted February 25, 2020 Share Posted February 25, 2020 Hey guys, got some questions. My vehicle is a Fiesta ST3 2016 model. 1. What PSI settings should I use for the wheels. I'm using pilot sport 4 at the moment on the front and rear. 2. When I top up my engine coolant how far should I fill it up if it's nearing empty (picture is after my drive. But my engine was overheating) 3. I've had this odd engine coolant cap problem now where it snaps my engine coolant cap in half forcing me to buy a new one. What could the cause of this be? I've read it's a common problem and a cheap fix as a first party cap is £10. But it's just annoying to have to replace every 6 months. Quote Link to comment Share on other sites More sharing options...
Bobr Posted February 25, 2020 Share Posted February 25, 2020 Next time you put your coolant cap on smear some silicon grease around the threads. That should cure the breakages. 2 Quote Link to comment Share on other sites More sharing options...
Xkalavous Posted February 25, 2020 Author Share Posted February 25, 2020 13 minutes ago, Bobr said: Next time you put your coolant cap on smear some silicon grease around the threads. That should cure the breakages. Ah I didn't know that.. last time this happened a garage fixed it so do you think they didn't do this? If I top up my coolant now do you think my overheating problem will not come back? Quote Link to comment Share on other sites More sharing options...
wilkinson Posted February 25, 2020 Share Posted February 25, 2020 1. Look in the handbook for the PSI pressures for your tyres. 2. Top the coolant up with the correct concentration of water to Ford coolant. Again look in your handbook for the information. Look carefully and you will see the level marks on the side of the reservoir. Your level in the picture is way too low which could count for some of the overheating. 3. Coolant caps breaking is a common problem with sometimes some of the cap stuck in the reservoir. Do as Bob says smear a thin layer of silicone grease around the seals etc. Make sure you have the correct Ford cap to pressurise the system. Again wrong or malfunctioning cap can cause overheating. 1 Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted February 25, 2020 Share Posted February 25, 2020 2 hours ago, Bobr said: Next time you put your coolant cap on smear some silicon grease around the threads. That should cure the breakages. The rubber O rings need greasing as well. 1 Quote Link to comment Share on other sites More sharing options...
Cal844 Posted February 25, 2020 Share Posted February 25, 2020 You should use 32 psi all round, but look inside the front door apertures below the latch just incase the pressures are different. It will have 2 or 3 different tyre sizes and loads. Ford have an upgrade cap but always put a smear of grease or oil on the threads of the cap and rubber seal. the reason the cap breaks is because the cap and rubber seal goes too tight and dry due to lack of use. 1 Quote Link to comment Share on other sites More sharing options...
Xkalavous Posted February 26, 2020 Author Share Posted February 26, 2020 Thank you guys! I've done all these tips, back to normal. Fingers crossed! Quote Link to comment Share on other sites More sharing options...
Cal844 Posted February 26, 2020 Share Posted February 26, 2020 Grease it once a month (more if its tight to get off) from now on. Quote Link to comment Share on other sites More sharing options...
