Chris_Y Posted May 26, 2020 Share Posted May 26, 2020 Got a Ka MK1 1.3. The AC will blow consistently cold upon a cold engine start up and will do this for an entire journey. If, however, I stop the car, switch off and then back on again it will only blow very hot. I know about the heater control valve issue with these but can't understand why it would make a difference if the car stopped running then was restarted... Any ideas anyone? Thanks. Quote Link to comment Share on other sites More sharing options...
Simon_Templar Posted July 24, 2020 Share Posted July 24, 2020 I have the exact same issue Plus, we already have changed the HCV (twice to be sure) and the control panel Any help would be *extremely* appreciated Thanx Quote Link to comment Share on other sites More sharing options...
tomshepp Posted September 22, 2020 Share Posted September 22, 2020 The car stops hot and the evaporator is cold . Then it will not blow cold air. The pump clutch comes in with a smack? If so, there is SOME pressure in the system. I would suspect a droplet of water blocking the orifice and would change the drier and recharge the system. Quote Link to comment Share on other sites More sharing options...
