Watch7ower Posted August 13, 2020 Share Posted August 13, 2020 Hi all, Hope you are doing well in these strange times. Last night, my home was broken into and the key-fob for my 2008 Focus was taken. Along with it, they also took the spare (manual) key. They did not take the car, however, as it wasn't as close to the house as normal so they were most likely not able to see the lights flash when attempting to use the fob. 1) I have a weirdly cut 3rd key which only unlocks the bonnet - not the driver's side door. To take precaution until my lock can be changed and I have a new set of keys, I have pulled the ignition and starter solenoid fuses from the engine compartment fuse panel. Would this be enough to stop the car from being taken if the thieves return and unlock the car? 2) With regard to sorting this mess out - I was offered the option of having a new key coded but I reiterated it's only half a solution as my other manual key has also been taken. So I'm assuming I must get the lock and ignition changed along with getting new keys to cover all my bases. Is this correct? 3) The 2 keys which were stolen can also unlock the bonnet - should I have this lock changed as well just in case? Lastly, does anyone known a reliable mobile service who could come to my address and sort it all out? I am awaiting a quote from the AA but expect it to be very steep. My insurance policy's total excess is £600 as I have only had a license since November 2016. Thanks in advance for any assistance on this. Quote Link to comment Share on other sites More sharing options...
Gaz0000000 Posted August 13, 2020 Share Posted August 13, 2020 If they come back and it doesn’t start they won’t waste time looking for a reason for it not starting so you would be okay .. so you could change all the locks and have new keys programmed for about £500 quid or so or you could get new keys cut and programmed for a coupled of hundred quid and doing so they will unprograme the stolen keys so they won’t start the car but the could still open the doors . If you wanted to save money that would prob be your best bet and invest in a steering wheel lock and you should be okay Quote Link to comment Share on other sites More sharing options...
Watch7ower Posted August 13, 2020 Author Share Posted August 13, 2020 Hi Gaz, Thanks very much for your response. So if I had new keys cut and programmed, the stolen key-fob could still open the door (by physical unlock only?) but not start the car as the ignition has been reprogrammed to only accept the new fob. What would happen if they tried the manual/standard key they also took though, or separated the other key from the fob and chip itself - would that still start the car and let them get away if no wheel lock was in place? Quote Link to comment Share on other sites More sharing options...
Milkman Posted August 13, 2020 Share Posted August 13, 2020 Your best thing would be to contact Ford UK or your nearest Ford dealer to give you advice on your questions and options available and also consult your insurance Company as to how you stand from an insurance situation and go from there. Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted August 13, 2020 Share Posted August 13, 2020 You want to change all the locks (including bonnet) to be on the safe side. If you don't change the barrels and just get 2 new keys cut, they won't be able to start the car (but still gain entry obviously). Your car has an immobiliser that can only be disabled with the correct chip that is paired with the ECU being placed close to the transponder ring. Removing those recognised chips from the ECU mean they'll no longer disable the immobiliser. I wouldn't go to Ford. They just outsource it to a local locksmith and charge you for the privilege. Quote Link to comment Share on other sites More sharing options...
Gaz0000000 Posted August 13, 2020 Share Posted August 13, 2020 Hi when you get your keys programmed there is an option within the sys to delete any previous keys , although the old keys will physically open and turn the ignition they won’t be able to start the car . Unfortunately all your options depend on how much money your willing to pay Quote Link to comment Share on other sites More sharing options...
Dark Andy Posted August 13, 2020 Share Posted August 13, 2020 I don't have a 2008 model, so this could be completely wrong but given physical access to the inside of the car through the physical key, would the thief then have access to the OBD port and from there be able to reinstate the keys that they have taken, to enable them to start the engine? Quote Link to comment Share on other sites More sharing options...
StephenFord Posted August 13, 2020 Share Posted August 13, 2020 Guys, it's a 2008 Focus, retail between £1500 and £2000. I'd be shocked if the key thieves would spend much time & effort in coming back, and stealing it. The most cursory precautions should be enough to see them off in search of a newer, more expensive car. I speak as someone whose car is worth little more than a few bags of peanuts! Honestly, see what the absolute cheapest option is to maybe change the immobiliser programming. The bonnet lock will have been faulty in the past and the owner took the lazy way out of getting a new generic barrel instead of making up the same one as your ignition key - I wouldn't worry about it. You have my sympathy, there are some right scumbags around and we all wish them eternal hell & damnation! Quote Link to comment Share on other sites More sharing options...
Alex.S Posted August 13, 2020 Share Posted August 13, 2020 37 minutes ago, Dark Andy said: I don't have a 2008 model, so this could be completely wrong but given physical access to the inside of the car through the physical key, would the thief then have access to the OBD port and from there be able to reinstate the keys that they have taken, to enable them to start the engine? That’s a lot of trouble to steal a 2008 focus. Chances are they’re not clever enough either. Is it an RS or ST ? Quote Link to comment Share on other sites More sharing options...
isetta Posted August 13, 2020 Share Posted August 13, 2020 Like said above. Get a lock that you put on steering wheel Quote Link to comment Share on other sites More sharing options...
Hooded Posted August 14, 2020 Share Posted August 14, 2020 Disklok .. problem solved Quote Link to comment Share on other sites More sharing options...
StephenFord Posted August 14, 2020 Share Posted August 14, 2020 7 hours ago, Hooded said: Disklok .. problem solved My own Disklok, now worth more than the car it protects! LOL 2 Quote Link to comment Share on other sites More sharing options...
Hooded Posted August 14, 2020 Share Posted August 14, 2020 15 hours ago, StephenFord said: My own Disklok, now worth more than the car it protects! LOL Haha.. you’ve got the sexy Chrome one, you don’t see many of those! Quote Link to comment Share on other sites More sharing options...
StephenFord Posted August 15, 2020 Share Posted August 15, 2020 8 hours ago, Hooded said: Haha.. you’ve got the sexy Chrome one, you don’t see many of those! I was flush at the time of purchase, not so much now LOL 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 15, 2020 Share Posted August 15, 2020 10 hours ago, Hooded said: Haha.. you’ve got the sexy Chrome one, you don’t see many of those! Must be worth a few bob on the black market now...he'll need some sort of security device to keep it safe! 2 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted August 15, 2020 Share Posted August 15, 2020 1 hour ago, TomsFocus said: Must be worth a few bob on the black market now...he'll need some sort of security device to keep it safe! I do, it's called a Ford Focus 🤣 1 3 Quote Link to comment Share on other sites More sharing options...
