sonic113 Posted September 9, 2020 Share Posted September 9, 2020 Does anybody know the exact torque values for for the 2009 focus. It's the 6 bolts that hold the rear subframe to the car? I have scanned Haynes manual but can't find them. They have the trailing arm bush bolts and the others but don't see the values for those main 6 bolts. Cheers Quote Link to comment Share on other sites More sharing options...
williamweb Posted September 9, 2020 Share Posted September 9, 2020 5 minutes ago, sonic113 said: Does anybody know the exact torque values for for the 2009 focus. It's the 6 bolts that hold the rear subframe to the car? I have scanned Haynes manual but can't find them. They have the trailing arm bush bolts and the others but don't see the values for those main 6 bolts. Cheers Maybe it's under crossmember mounting bolts.My MK1 is 115 Nm if that helps👍 1 Quote Link to comment Share on other sites More sharing options...
sonic113 Posted September 9, 2020 Author Share Posted September 9, 2020 6 minutes ago, williamweb said: Maybe it's under crossmember mounting bolts.My MK1 is 115 Nm if that helps👍 Rechecked no, still don't see it. Will have a Google and check Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 9, 2020 Share Posted September 9, 2020 Pm me your reg, I’ll check for you. Quote Link to comment Share on other sites More sharing options...
sonic113 Posted September 9, 2020 Author Share Posted September 9, 2020 Just now, stef123 said: Pm me your reg, I’ll check for you. Thanks, will pm it now. Quote Link to comment Share on other sites More sharing options...
iantt Posted September 9, 2020 Share Posted September 9, 2020 125nm 1 Quote Link to comment Share on other sites More sharing options...
sonic113 Posted September 9, 2020 Author Share Posted September 9, 2020 Just now, iantt said: 125nm For the whole 6 of them? Quote Link to comment Share on other sites More sharing options...
iantt Posted September 9, 2020 Share Posted September 9, 2020 Yep Quote Link to comment Share on other sites More sharing options...
iantt Posted September 9, 2020 Share Posted September 9, 2020 I'm assuming it's hatchback and not estate? Edit, estate the same anyway 1 Quote Link to comment Share on other sites More sharing options...
sonic113 Posted September 9, 2020 Author Share Posted September 9, 2020 1 minute ago, iantt said: I'm assuming it's hatchback and not estate? Yes the MK2.5 hatchback Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 9, 2020 Share Posted September 9, 2020 I’ve got 115Nm here but close enough lol Quote Link to comment Share on other sites More sharing options...
sonic113 Posted September 9, 2020 Author Share Posted September 9, 2020 So what shall it be 115 or 125NM? Or I hit it at 120NM that should so it. Quote Link to comment Share on other sites More sharing options...
iantt Posted September 9, 2020 Share Posted September 9, 2020 Stef would say 3 dugga duggas 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 9, 2020 Share Posted September 9, 2020 Took the words right out of my mouth Ian Gotta be careful with the dugga duggas on these Milwaukee 3/4” guns 1 1 Quote Link to comment Share on other sites More sharing options...
sonic113 Posted September 9, 2020 Author Share Posted September 9, 2020 Thanks fellas , helped me out s lot this evening, appreciate it. 👍👍 Quote Link to comment Share on other sites More sharing options...
sonic113 Posted September 9, 2020 Author Share Posted September 9, 2020 Just when we're here, I have new control arms installed . I will have to get the car realignment done but is there any neutral way to adjust these bolts untill then or does it not matter which which they go? At the moment I have them both facing the same way on both sides. Quote Link to comment Share on other sites More sharing options...
