spannerman0785 Posted January 2, 2021 Share Posted January 2, 2021 I am currently due to start an engine replacement on a 2018 ford courier 1.5 diesel. Engine code xxcc. I have a complete engine with wiring loom ready to fit. Can anyone tell me what, if any components will need to be swapped from the old engine to the replacement unit to avoid any immobiliser issues ? Quote Link to comment Share on other sites More sharing options...
fordpartsman Posted January 2, 2021 Share Posted January 2, 2021 It may not cause immo issues but it may be worth either swapping or coding to injectors once the swap is done. This is due to the learned fuel injector quantities etc that the ecu knows Quote Link to comment Share on other sites More sharing options...
spannerman0785 Posted January 2, 2021 Author Share Posted January 2, 2021 so the engine will run without any swapping of components ? Obviously all old components will be retained for future use its just the vehicle needs t o be back in service on jan 7th. Thanks Quote Link to comment Share on other sites More sharing options...
fordpartsman Posted January 3, 2021 Share Posted January 3, 2021 Providing that you are retaining the original ecu for the van body that it is going into, I cannot see any obvious reason why it should not run Quote Link to comment Share on other sites More sharing options...
spannerman0785 Posted January 3, 2021 Author Share Posted January 3, 2021 ok thanks for your help Adam Quote Link to comment Share on other sites More sharing options...
spannerman0785 Posted January 4, 2021 Author Share Posted January 4, 2021 been informed today that the fuel pump is coded to the vehicle and will need to be taken off and fitted to the replacement engine. can anyone confirm thi or shed any more light on the matter ? Thanks Neil. Quote Link to comment Share on other sites More sharing options...
spannerman0785 Posted January 4, 2021 Author Share Posted January 4, 2021 Sort of makes sense as i recall the old focus diesels and mk6 and 7 transits have coded pumps Quote Link to comment Share on other sites More sharing options...
