Disable parking sensors
I want to disable my rear parking sensors on my 2015 focus. But there is no option in the menu or button on the dashboard. Am I missing something or is there no way to disable them on my model of car?
Have a look in the menu on the dash, it should be under driver convenience (assuming you don't have a physical button with a P on it). It only turns it off for that particular journey though and defaults to on when you cycle the ignition.
If you want a long term solution you will need to use Forscan
or...go old school and stick some tape over them, that'll stop the buggers from working!
Depends on whether you have genuine sensors factory fitted or aftermarket ones how you go about disabling them.
