jay1919 Posted June 11, 2021 Share Posted June 11, 2021 hello having great difficulty removing the outer driver side cv joint from the shaft any one got any tips ,wont come off with a hammer struggling isnt the word thanks jason Quote Link to comment Share on other sites More sharing options...
Phil3747 Posted June 12, 2021 Share Posted June 12, 2021 Are you sure there isn't a circlip holding it on ?? Quote Link to comment Share on other sites More sharing options...
mjt Posted June 12, 2021 Share Posted June 12, 2021 Looking at Haynes it would appear that the outer CV joint can not be separated from the driveshaft. If it is necessary to replace the gailter it must be done by removing the shaft from the inner tripod joint. In the past CV joints were usually retained with a spring ring on the end of the shaft, with the joint ball cage chamfered so that tapping with a hammer would compress the ring into the chamfer until the shaft could be withdrawn. It looks as if modern ones have the joint fixed so that it can only be renewed together with the shaft as a complete unit. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 12, 2021 Share Posted June 12, 2021 I didn't know anyone still changed singular CV joints. Horrible messy job!! If you're only trying to change the gaiter, buy a stretch fit one instead. Quote Link to comment Share on other sites More sharing options...
