Keyless start retrofit
Swearwolf
Hi all
almost finished installing full keyless entry/start on a 2007
right at the end now, i've got it all working, with the fob in car the steering lock disengages, i hear a click when pressing clutch which releases the ignition barrel, i can turn it on to accessories etc but when i turn to crank car there's nothing lol, and it comes up on dash "please engage steering lock" as if i've just turned car off.
probably going to be trial and error but wondering if anyone has ideas?
thanks 😄
I admire your pluckiness on a challenging installation, but can't help feeling with the number of threads on here on how to disable 'keyless' operation because of security issues, you may regret it. Still, good luck in getting it to work, and don't forget to buy a Disklok to keep you car safe...
50 minutes ago, Swearwolf said:
Hi all
thanks 😄
Did you also reconfigure/reprogram the PATS immobilizer system?
On the Focus MK2/C-Max MK1 with conventional ignition key the PATS immobilizer system is controlled by the instrument cluster
On the Focus MK2/C-Max MK1 with keyless start the PATS immobilizer system is controlled by the KVM module.
If the PATS immobilizer system is not configured/reprogrammed correctly the car will not start.
  • Like 2
I did via elmconfig, change the PATS from "standard PATS" to "old style KVM" in the HEC section
However the KVM now reports error "keyless module security mismatch" (or something I cant quite remember lol)
He needs the up-market keyless Disklok  🤣
  • Haha 1
This is just a thought but is the PATS system still in use and reading your keyfob or is that part of the system no longer used ?
If you take the transponder chip out of your key and place it next to the induction aerial loop that used to be next to your old ignition barrel does the car then start ?
hi mate
nope! unfortunately not. i'm sure the pats is ok as the red light on cluster comes on solid initially then goes off - just as before, so seems to be accepting it. can hear the KVM click like a relay when i try to crank
Well I guess thats a good thing. Since the original system would not have been using the KVM are all the contacts actually wired ?
Since on a keyless vehicle the PATS immobilizer functionality is controlled by the KVM module the system needs to be programmed correctly.
The transponder keys (keyfobs) need to be programmed into the KVM (which is already the case if the keyfobs and KVM came from the same donor vehicle). Apart from this the KVM needs to be paired/synchronised with the PCM. This procedure is called PATS initialization in the Ford diagnostic systems.
If the PCM is still paired with the instrument cluster and not with the KVM module the engine will never start.
  • Like 3
Thanks, guys
I am using forscan
when I attempted what’s called “module initialisation” on the IC it says “not available on keyless vehicle, use KVM”
fair enough
go to do the same on KVM menu, “the PATS is not initialised please run the function from main menu”
Seem to be stuck in circles
Yes, the car was already wired for everything keyless luckily
however I have an orange/grey and green/white wires twisted together that i do not know where they go as they’re not on any wiring diagrams
I know this may be a daft question, but you do have the full paid for licenced version of ForScan?
I read about retro fit this and that on here a lot. This is by far the most ambitious, are you going to retro fit stop start next ? 😉
I do indeed mate
I'll try anything... just found the slot for the relay for it in the engine bay....and it's wired....
Small update
Apparently need to clear all keys, program 2 new (or used lmao) keys, then do module initialisation and it should work. Well erased all keys now it wont let me program any LOL
OH B0llocks woud be my thoughts 😟
still in trouble on this one guys, and desperate for any help that's out there
as said i erased all keys. i have 2 genuine ford keyless fobs with good batteries..
everytime i go into forscan to program a key, it grants security access and says press any button on fob, so i do - the KVM clicks like a relay - then forscan says PATS key programming failed
both keys, every single time.... so now i have 0 programmed keys, and ive tried for days and days
Hi George, sorry to hear of your key problem.
I assume that you know that there are two diffrent actions to a key, but just encase heres some info.
(a) Transponder Chip (passive) - no battery required. This is what the car reads to check key is correct and turn off the PATS immobiliser.
(b) The keyfob buttons - Needs a battery to work. These buttons can be used to lock/unlock the car.
I have never tried to programme a key in to the car, but I would expect it to be a two stage process. First the transpoder chip, then second the keyfob buttons.
It sounds to me like you are only doing the keyfob buttons and not programming in the transpoder chip. Sorry if my thoughts are wrong.
hi unofix, thanks for the reply 🙂
small success today!!
i persisted and have managed to program both keys to pats and entry
strangely enough, the thing that worked was unplugging all of the interior sensors.... lord knows??
it unlocks car, steering column etc but now onto the fact it wont crank the engine again lol
Would love to be able to help but I'm out of ideas just now.
Did you ever manage to do what @JW1982said ?
i have tried unsuccessfully 😞 i can choose the RKE module and select module initialization - it then just errors and tells me PATS is not initialized
  • Sad 1
Hmmm just reading through this and it looks like you've done everything correctly, I'm wondering if @unofixis right and you need something like IDS (basically the licensed ford version of Forscan) that is actually connected to Fords security database to initialise this change 🤔
quick update for anyone interested
i've been working with the FORScan team on a fix, as it turned out to be a bug in the program, as this has never been attempted before...
after 4 new test builds we were able to initialise the module successfully, which allows me to start the car but only with the emergency key inserted. with no key it's still a no crank. but watch this space...
  • Like 2
  • Thanks 1
WELL DONE !! 👍 🎉
Most would have given up by now. Thanks to people like you taking the time to get through projects like this others will be able to do this in the future. I hope that since you are almost there now that Forscan will continue to support you and get the final bit working and allow you to finally programme the keys.
Once finished be sure to tell the insurance company, as your car will have more than doubled in value with all the extra work you've done 🤣
  • Insurance
  • Support
