ThomvB Posted August 12, 2022 Share Posted August 12, 2022 Hello there, I have been strugeling to get my rear Speakers to work in my 3 door fiesta from 2009. To explain the situation: I found out my fiesta did not have rear Speakers, although the fader option is available to change front/rear sound difference. So I bought some Speakers with the nessesary equipment like the rings and plugs to connect te speaker. At first I thought the speakers were broken, but then I did a power test on the plug that came out of the car(so not on the plug connected to the speaker) and came to a conclusion no power was sent to the cable. I have read on a forum that its possible that u need to activate the radio into knowing there are 4 speakers instead of the 2 in the front seat doors. Can anyone help me with it?? Kind regards, Thom Quote Link to comment Share on other sites More sharing options...
alanfp Posted August 13, 2022 Share Posted August 13, 2022 20 hours ago, ThomvB said: I did a power test on the plug that came out of the car Hi - 1.Can you explain exactly which plug you are talking about? 2.If it didn't have Speakers when you got the car, and you say you bought all the necessary kit, did you have to buy new wiring, or was the wiring already there? 3.Also, do you know if it's the original radio or a replacement? 4.Is there a brand name on the radio anywhere? Quote Link to comment Share on other sites More sharing options...
Jimpster Posted August 13, 2022 Share Posted August 13, 2022 14 minutes ago, alanfp said: Hi - 1.Can you explain exactly which plug you are talking about? 2.If it didn't have speakers when you got the car, and you say you bought all the necessary kit, did you have to buy new wiring, or was the wiring already there? 3.Also, do you know if it's the original radio or a replacement? 4.Is there a brand name on the radio anywhere? also have you acess to FORscan if you think it needs activating, it may be if its the original factory fitted unit Quote Link to comment Share on other sites More sharing options...
ThomvB Posted August 14, 2022 Author Share Posted August 14, 2022 On 8/13/2022 at 4:27 PM, alanfp said: Hi - 1.Can you explain exactly which plug you are talking about? 2.If it didn't have speakers when you got the car, and you say you bought all the necessary kit, did you have to buy new wiring, or was the wiring already there? 3.Also, do you know if it's the original radio or a replacement? 4.Is there a brand name on the radio anywhere? I was talking about the plug where you connect your speaker to the wiring harness. I didnt but a complete kit, I ordered the necessary things like the mounting bracket and the wire adapter. And ofcourse fitting Speakers. Its the original radio from ford. I had already looked a lot on internet. But after about another 3 hours of searching on the internet, I found a video of someone who had the same car and the issue, and in the video they talked about the wire not being fully inside the wiring harness. Since there is another wiring plug rivgt before the cables go into the dashboard. The speaker wires did not continue from the plug to the radio. Havent had the time to take a look at it since I saw the video. But I will give a shot tomorrow after work. I'll keep you al posted. 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted November 29, 2022 Share Posted November 29, 2022 On 8/14/2022 at 9:48 PM, ThomvB said: ...But I will give a shot tomorrow after work. I'll keep you al posted. So, you decided not to 'keep us posted' after all?? 3 Quote Link to comment Share on other sites More sharing options...
