2020 1.0 ecoboost newer chain driven, enging noise when cold
Option 4
 Share
Hi I have a 1.0lt ecoboost 2020 Puma Titanium with 20000 miles on, its the newer chain driven engine, I was wondering if anybody else has the same problem as me. It has a rattleing or tingling noise when starting from cold, it lasts for about 25 seconds then goes, any advice will be appreciated.
Tthis is the video sound below
https://clipchamp.com/watch/VGS0S6boroW
  • Like 1
Link to comment
Your profile says it's a 2023 model ?
Link to comment
My new(ish 4000 miles) cam chain version 1.0L Ecoboost has always made a few clattery/tappity noises when cold - particularly so in those freezing spells last winter. After a mile it has quietened down.
Link to comment
Opps, sorry slip of the finger , ive corrected it now 2020
  • Haha 1
Link to comment
  • 3 weeks later...
On a similar theme, I have a 2020 puma hybrid with 20,000 miles on the clock. Couple of months ago it started a tapping/rattle but only when the engine is at normal temperature. Ford tech department say it’s normal but I’m not sure, why is it only a recent thing?
Link to comment
Has the oil & filter been changed recently?  If it's contaminated with petrol from short, cold runs and GPF regens then it may be a bit thin towards the end of the 2 year servicing schedule, which would show up more when the oil is warm.
  • Like 1
Link to comment
What year did these engines go from wet belts to chains. My engine code is BZJA
Thanks in advance
Link to comment
It varies, all MHEV are chain. Some later non MHEV are chain, most are belt but that seems to be pot luck as Ford seemed to fit whatever engine they had on hand for some models. If your turbo is at the front it's belt, at the back it's chain.
Link to comment
BZJA is a 155 MHEV chain cam.
All the current model Puma are chain, as is the Mk 4 Focus. As Andrew mentions, the Fiesta is more complicated - the chain cam was phased in from mid 2020, but some versions with the 100ps engine seem to have remained wet belt.
  • Like 1
Link to comment
Thanks guys, I've "heard" some horror stories about the belt drives.
What sort of maintenance schedule is there for the timing chain?
Link to comment
None for the chain.
Auxiliary belt on the MHEV is recommended every 4 years or 72k.
oil pump belt is recommended every 10 years or 144k.
oil & filter change is every 2 years or 18k.
Spark plugs & air filter are every 4 years or 36k.
  • Like 1
  • Thanks 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
