abutters93 Posted March 1 Share Posted March 1 Hi everyone, I’ve got a 2010 S-Max 2.2 TDCi with 120k on the clock. It has an intermittent issue where the engine will idle/run rough and there’s a diesel smell in the cabin. It also occasionally throws an engine malfunction light but not for long. The fuel economy seems to go down and most of the time switching the ignition off and on again resolves it. I’ve scanned it for codes and it came back with “p02e5:71-28 diesel intake air flow control stuck closed” has anyone come across this before? Does this mean the throttle valve is getting stuck? Or is it not working as expected? Any help appreciated cheers Quote Link to comment Share on other sites More sharing options...
ChrisHoskins Posted March 21 Share Posted March 21 Same car/engine, with the same issues at 137k. only difference is my engine light stays on all the time. Did you manage to figure out what the fault was? Thanks. Quote Link to comment Share on other sites More sharing options...
abutters93 Posted March 21 Author Share Posted March 21 Hey Chris, Yes - the plastic gears inside the throttle body had stripped. It’s quite a common issue on the 2.2, the throttle body is shared with various PSA/JLR models. I bought a replacement from GSF, part no. is PIE7.01002.09.0, replacing it is pretty straightforward. The other option is to search eBay for metal replacement gears; they’re quite a bit cheaper and will be a more durable fix, but from the reviews you’ll need to do some fettling to get them on and prising open the throttle body is a bit of a pain as it’s pressed on. I opted for the unit replacement as I couldn’t have the car down for too long. Hope that helps! 1 Quote Link to comment Share on other sites More sharing options...
abutters93 Posted March 21 Author Share Posted March 21 Here’s the pictures of the stripped gears 1 Quote Link to comment Share on other sites More sharing options...
