lugo Posted May 1, 2011 Share Posted May 1, 2011 hi all, had the cam belt changed on my 1.8 derv focus 2 months ago. recent weeks it has started to smoke badly. under hard acceleration it pushes out heavey black smoke? exhust is sooted up. my guess is over fueling am i on right track. is there any adjustment on feul pump?? your help is much appriciated andy Quote Link to comment Share on other sites More sharing options...
Sara Fiesta Posted May 1, 2011 Share Posted May 1, 2011 I found this on a site may be the problem i don't know???? A common problem is the EGR valve sticking in the open position. This will cause excessive black smoke from the exhaust and will result in a lack of performance. Quote Link to comment Share on other sites More sharing options...
lugo Posted May 2, 2011 Author Share Posted May 2, 2011 thanks for that where did u find that. performance is fine tho. having the time to look at it is prob . will have to make some time doing my head in now Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 3, 2011 Share Posted May 3, 2011 The lack of performance tends to be dependant on the presence and state of the DPF filter. Without a DPF you are more likely to keep the power as it is, however with one, if the thing is getting on a bit, you will find that it will be clogged, and that will reduce the power output, as it backlogs on the Turbo, and the exhaust... Quote Link to comment Share on other sites More sharing options...
Sara Fiesta Posted May 6, 2011 Share Posted May 6, 2011 Sorry for the delay in answering, I was researching my problem and I came across a focus known faults list but I didn't save it and now I can't find the site! Quote Link to comment Share on other sites More sharing options...
cressws1 Posted May 8, 2011 Share Posted May 8, 2011 Sorry for the delay in answering, I was researching my problem and I came across a focus known faults list but I didn't save it and now I can't find the site! Was it this one? Quote Link to comment Share on other sites More sharing options...
Sara Fiesta Posted May 8, 2011 Share Posted May 8, 2011 Yeah that's the one thanks Quote Link to comment Share on other sites More sharing options...
lugo Posted May 10, 2011 Author Share Posted May 10, 2011 since been told its a boost problem from what the fault code is saying . still not had chance to take to get it sorted. :-( Quote Link to comment Share on other sites More sharing options...
Sara Fiesta Posted May 11, 2011 Share Posted May 11, 2011 Boost problems, wastegate fault, broken hose what's the air filter like clogged? Quote Link to comment Share on other sites More sharing options...
