jeebowhite Posted January 26, 2016 Author Share Posted January 26, 2016 Absolutely, though even cheap Chinese can work and can give you basic troubleshooting capabilities, more than you may have otherwise. If you find any good links, feel free to share them here Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
frund Posted February 1, 2016 Share Posted February 1, 2016 This may be the wrong place to ask, perhaps I should enter a new post but do we discuss ECU remapping via OBD. I realise you need bits of kit also prog for laptop and a knowledge of what improvements to make and when not to 'improve'. Is this subjuct the the domain of tuning Shops and specialists. I saw this item on the bay. SMPS MPPS OBD2 ECU Flasher Remapper EDC16 Metal Box Chip V13 For BMW Audi Ford Mod move if necessary. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 2, 2016 Author Share Posted February 2, 2016 there are kits which claim to allow you to remap, but I personally wouldn't, its not like a "go faster" switch, as you say there is a lot to it. I dont believe any current members have remapped their cars with such a kit, you are more than welcome to start a heard but I wouldnt expect many replies, beyond taking it to a specialist. Quote Link to comment Share on other sites More sharing options...
frund Posted February 2, 2016 Share Posted February 2, 2016 Yes probably best left to the chaps who do this sort of stuff daily. Could end up with a large problem. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted March 10, 2016 Author Share Posted March 10, 2016 Just watching "Supercar Megabuild". They just used Torque to diagnose a Throttle Position Sensor fault on a G Wagon for a build. Free software for the win! Quote Link to comment Share on other sites More sharing options...
chemfusion Posted April 6, 2016 Share Posted April 6, 2016 Came across this document showing what OBD protocols various Ford models use, it might me useful to some http://www.runtek.it/FORD%20_OBD.pdf Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 6, 2016 Author Share Posted April 6, 2016 most adapters are capable of running across most if not all of these protocols anyway :D Quote Link to comment Share on other sites More sharing options...
Artful dodger Posted May 30, 2016 Share Posted May 30, 2016 Good morning Gents, Quick bit of background, I've been on the spanners since 1985 but mainly on plant, modern cars confuse me a bit, My brother in law has a 2008 smax 2.0 diesel with code P0234, Car drives lovely up to 70, if he puts his foot down after that it will go into limp home unless he switches in the key off & on again, I have read some bit n pieces online but thought i would ask you fellas, Cheers Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 30, 2016 Share Posted May 30, 2016 Generic: Turbocharger (TC), engine boost condition – limit exceeded. http://wiki.ross-tech.com/wiki/index.php/16618/P0234/000564 Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 7, 2016 Author Share Posted June 7, 2016 that can also be triggered if I am not mistaken by a high fuel rail pressure Quote Link to comment Share on other sites More sharing options...
marc empson Posted January 10, 2017 Share Posted January 10, 2017 Hi ya i Need my mot done but iv got a problem i noticed yesterday. my left hand side lights front and back are not working. I have changed bulbs and checked fuses but still nothing was wondering if this is something you guys would be able to give any advice on? Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted January 11, 2017 Share Posted January 11, 2017 Have you looked in both fuse boxes Marc? Ford wire their cars in halves apparently rather than front and back. It could also be a dodgy earth on a bulb that 'looks' ok. Try swapping all the easily accessible bulbs from the rhs to the left. If It works then swap each bulb back separately, when you insert a bulb that's developed a faulty earth the lights will stop working and there is your answer. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
elson_cj Posted January 23, 2017 Share Posted January 23, 2017 Hi, New poster, hoping all you can help a very distressed ford owner!! The EM light has come on and I have a reader which gives me a couple of codes. One was the coil pack which has since been replaced and has prevented an issue I saw before where the car would Rev by itself.. However, I am getting the following codes:P0130P0150U0001P2298P0158All relate to the Oxygen Sensors(s). I had a lambda sensor replaced in November. But looking especially at P0158 it sounds like the Cat converter has failed.... Any ideas.. Hopefully it'll work but I have attached 5 photos confirming all codes. Quote Link to comment Share on other sites More sharing options...
AlexMack86 Posted February 20, 2017 Share Posted February 20, 2017 Hello folks, Can anyone tell me if these can be used to diagnose reason behind non-functional lamps?... I'm banging my head against a brick wall on this one. Bit of background info: Both side lamps not working - timing of fault unkown New bulbs installed - no fix Checked fuses 124 & 125 - continuity good Power cycled battery (disconnect neg pol, leave 15 mins) - no fix Any ideas as to what else it could be? I've heard iterations of a faulty switch, and to test if there is 12VDC at the light fitting. Still to try the latter Any help huuuugely appreciated. I'm sure it's something I can resolve without spending £££s at a garage. Cheers, Alex Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted February 20, 2017 Share Posted February 20, 2017 What is the model of car? Have you checked continuity within the fuses with a multimeter or the naked eye? Do the tail lights illuminate when the switch is on 'side lights'? When you turn on dipped beam do the side lights also illuminate? Are you using incandescent bulbs are LED? The polarity may not be right if it's the latter.Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Quinncey Posted March 18, 2017 Share Posted March 18, 2017 Hi there, New to the site, I just purchased a 2006 focus 1.6 TDCI. it was running fine when I bought it but now it is very sore on diesel, (70 miles to quarter tank) yesterday it put a red warning light on the dash a cog with ! mark inside. I got a friend to scan and have attached the report. It seems to have quite a few faults. Can someone on here help shed some light on this for me as I am not sure. are they big/costly fixes? Thanks in advance Killian Focus 1.6 TDCI.pdf Quote Link to comment Share on other sites More sharing options...
Mr Glyn Posted March 28, 2017 Share Posted March 28, 2017 Thank you James 1 Quote Link to comment Share on other sites More sharing options...
czcina Posted March 28, 2018 Share Posted March 28, 2018 Hi. I found three codes: C184_00 ; C074_88 and C257_00. They are showing up only when I go into "test" mode ( press and hold OK on steering wheel and ignition on ) and scroll down in the menu under DTC Codes. Nothing comes up when using OBDII reader?! Can't find those codes anywhere as most of them start with "P" not "C" like in my case :( Any idea what it could be? I do have a problem now with my radio that switch itself off and on at random... Ford Focus MK3, 2013, diesel. Thank you Quote Link to comment Share on other sites More sharing options...
Leefefc Posted August 17, 2018 Share Posted August 17, 2018 Hello, Can anyone tell me what this is ? 1.6 2013 TDCi Thanks Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 17, 2018 Share Posted August 17, 2018 4 minutes ago, Leefefc said: Hello, Can anyone tell me what this is ? 1.6 2013 TDCi Thanks Auxilliary belt tensioner. This isn't really the right place for that post though. Quote Link to comment Share on other sites More sharing options...
Leefefc Posted August 17, 2018 Share Posted August 17, 2018 Thanks tom Quote Link to comment Share on other sites More sharing options...
magor226 Posted December 4, 2019 Share Posted December 4, 2019 Great thread. Got some issues with my 2004 focus so might look into one of these. Can anyone recommend one please? Michael Quote Link to comment Share on other sites More sharing options...
magor226 Posted December 10, 2019 Share Posted December 10, 2019 I've just bought a ELM327 bluetooth adaptor for my 2004 1.8 Tdci Focus and it won't connect to the cars ECU. Is the ELM327 compatable with my car? Quote Link to comment Share on other sites More sharing options...
Gary069 Posted January 7, 2020 Share Posted January 7, 2020 Hi, I own a Ford Focus 2005 and am having trouble with the boot opening. The boot was working fine until one day it didn’t open and then it would only open on the odd occasion. W shave tried replacing the switch and also the latch with no luck, we have tested fuses but can not find a fault, please help as we really need a boot. Quote Link to comment Share on other sites More sharing options...
Mark13 Posted February 2, 2020 Share Posted February 2, 2020 Hi Got an issue with my 2013 Ford Focus Stereo/radio/Bluetooth etc has stopped working - only got the Ford Audio display up and that’s it. Rear parking sensors only work on display but no warning noises anymore Any ideas anyone? Any help appreciated Thanks Quote Link to comment Share on other sites More sharing options...
