screamer Posted April 18, 2013 Share Posted April 18, 2013 as above, on a 2002 Fiesta, older style, just changed the thermostat & coolant. does it sound as if it's blocked with sludge/crap etc? as looking into the thermostat housing & block, it was very clean i did put a hose into the thermostat housing and water came out of the small drain plug on the radiator and it flowed with clean water, then i did the same into the top radiator hose fitting, clean water as well. ??? cheers Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 18, 2013 Share Posted April 18, 2013 Does sound like its sludged up. What colour was the anti freeze when you changed it? Rusty orange colour? Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 18, 2013 Share Posted April 18, 2013 Thos is pretty normal, both hoses won't get hot until the engine is hot enough and the thermostat opens. I take it the car is not overheating? Take the car for a drive and then check the hoses Quote Link to comment Share on other sites More sharing options...
screamer Posted April 18, 2013 Author Share Posted April 18, 2013 Thos is pretty normal, both hoses won't get hot until the engine is hot enough and the thermostat opens. I take it the car is not overheating? Take the car for a drive and then check the hoses i'll take it out for another wee spin and see what the bottom hose feels like it's not overheating, it's mainly used on short journeys but we have taken it on a 200 mile round trip a few months ago without any problems Does sound like its sludged up. What colour was the anti freeze when you changed it? Rusty orange colour? the coolant wasnt too bad, when it wa draining out of the wee drain plug, you could still see the pink colour when i stuck the hose into the top of the raidator, it flowed with clean water, as if it was dirty looking i would've kept on washing it out and i would've tried to take off the bottom hose (probably never been off since new!!) and wash it from there Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 18, 2013 Share Posted April 18, 2013 I wouldnt worry about it too much then 1 Quote Link to comment Share on other sites More sharing options...
screamer Posted April 18, 2013 Author Share Posted April 18, 2013 cheers for the quick replies guys, appreciated Quote Link to comment Share on other sites More sharing options...
screamer Posted April 18, 2013 Author Share Posted April 18, 2013 update, just back from a 20 minute run, the bottom hose is quite warm. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 18, 2013 Share Posted April 18, 2013 Thermostat is working normally. 1 Quote Link to comment Share on other sites More sharing options...
