Nathan54771 Posted June 20, 2013 Share Posted June 20, 2013 Has anybody got any pictures of there car with them on at night ? eager to see them seen as my car is 8 weeks away from delivery :( Quote Link to comment Share on other sites More sharing options...
bigmunkynutz Posted June 20, 2013 Share Posted June 20, 2013 They look like the one in your profile pic mate. The ZS don't have LED DRLs... Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted June 20, 2013 Author Share Posted June 20, 2013 I see I see, what bulb are they then ? :s more than one ? Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted June 20, 2013 Share Posted June 20, 2013 They're an H15 bulb. Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted June 20, 2013 Author Share Posted June 20, 2013 Just one bulb on each side for DRL or ? If thats the case then there's 2 h15's on each side ? (Full beam and DRL) Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted June 20, 2013 Share Posted June 20, 2013 The DRL is built into the main/high beam bulb, so you have your indicator bulb, sidelight, dipped beam and main beam in the light unit. So it's 1 H15 bulb at either side, 2 for the whole car. Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted June 20, 2013 Author Share Posted June 20, 2013 Ahhh okay I see I see makes sense now then, that's definately an unusual one. Thanks for your help Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted June 20, 2013 Share Posted June 20, 2013 They're found in VW's, Audi's and Dacia's I believe, not sure where else, but quite a few manufacturers are using them now. Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted June 20, 2013 Author Share Posted June 20, 2013 Hopefully they start to produce some aftermarket versions of the bulb type then soon Quote Link to comment Share on other sites More sharing options...
SgtHobNob Posted June 21, 2013 Share Posted June 21, 2013 Do the titanium LEDs turn off at night or dim? Are they used as side lights? Quote Link to comment Share on other sites More sharing options...
cuke Posted June 21, 2013 Share Posted June 21, 2013 Hi, the drl's dim when you turn on the switch to sidelights/headlights.. Quote Link to comment Share on other sites More sharing options...
