davesy Posted April 7, 2009 Share Posted April 7, 2009 Hi All. Can anyone advise if there is a way of temporarily converting the adaptive style headlights on my 07 S-max 2.5t with x pack. I live in the U.K and am planning atrip to mainland Europe where I may have to drive at night. I know you can get the stick on external masks but I am unsure if this will work with adaptive headlights. I did read something about a way of temporarliy changing reversing the beam but am unsure if this can be done DIY. Any help would be appreciated. Cheers Quote Link to comment Share on other sites More sharing options...
mintalkin Posted April 7, 2009 Share Posted April 7, 2009 on the xenon headlights there is a switch under the bulb/ light covers to swop the beam patten to europe, might be worth a look for the same on yours. Quote Link to comment Share on other sites More sharing options...
sobaka Posted April 8, 2009 Share Posted April 8, 2009 on the xenon headlights there is a switch under the bulb/ light covers to swop the beam patten to europe, might be worth a look for the same on yours. I am sorry, there is no switch on the smax headlights. As for converters yes, they exist. Have a look at the last post in newbie questions topic I have posted a link there. Quote Link to comment Share on other sites More sharing options...
fordtech Posted April 8, 2009 Share Posted April 8, 2009 See if this worksSmax_hlamp_conversion.htm 2 Quote Link to comment Share on other sites More sharing options...
homeless Posted April 11, 2009 Share Posted April 11, 2009 See if this worksSmax_hlamp_conversion.htm True this is the way to do it...make sure you do two templates though, one white, one black on each side, black will go over the white, this will prevent a heat build up on your plastic lense which will melt and distort (iam taking about the headlight actally melting here)if you just fit the black! As you all know black absorbs the heat.....i have tried this process and it works! 1 Quote Link to comment Share on other sites More sharing options...
Gryphea Posted July 31, 2010 Share Posted July 31, 2010 See if this worksSmax_hlamp_conversion.htm Can I just say a big THANKS for this. Quote Link to comment Share on other sites More sharing options...
h_0481 Posted June 21, 2011 Share Posted June 21, 2011 I have a similar problem. I am moving to Germany for a while and would like to convert my 56 plate headlights. Would a set of 2010 S max Hlights fit directly onto my car?? Quote Link to comment Share on other sites More sharing options...
GordonF Posted August 10, 2011 Share Posted August 10, 2011 See if this worksSmax_hlamp_conversion.htm Hi - I've just come across this post and am concerned that the images shown are symmetrical. Usually I would expect the masking to be the same side on each headlamp rather than the symmetry shown here on these pictures (because you need the block the beams that dip to the left on each headlight). Does this symmetrical masking really work? Quote Link to comment Share on other sites More sharing options...
Billfractures Posted June 30, 2020 Share Posted June 30, 2020 Just bought a 2016 s max auto 7 seater 150 titanium x pack. Wanted to check the headlights for driving in Europe. There are NO switches under the bulbs BUT they can be changed via the engine setting-headlight- LHD or RHD on the steering wheel. Bill. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 30, 2020 Share Posted June 30, 2020 Sent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
CombTech Posted July 1, 2020 Share Posted July 1, 2020 On 6/30/2020 at 12:10 PM, Billfractures said: Just bought a 2016 s max auto 7 seater 150 titanium x pack. Wanted to check the headlights for driving in Europe. There are NO switches under the bulbs BUT they can be changed via the engine setting-headlight- LHD or RHD on the steering wheel. Bill. Hi On my 2017 S-MAx there is a setting in the onboard tech that allows the setting Adaptive Headlamp in the Information Display. Quote Link to comment Share on other sites More sharing options...
