mixmasterlooney Posted May 19, 2014 Share Posted May 19, 2014 Using the photos you've sent me i can clearly identify almost all of the wiring harness Here is a photo i took doing puddle lights couple months ago, you can see where the green and blue connector goes, including the switch connector Another view Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted May 19, 2014 Share Posted May 19, 2014 When i had a good search under the steering column my efforts were mostly focused on the left hand side of the steering has shown in the pics provided by JW Like i said though i saw no where to connect or attach the module, i now believe it's on the right hand side of the steering wheel behind the light switch or vents Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted May 19, 2014 Share Posted May 19, 2014 Photos from under the steering column Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 19, 2014 Author Share Posted May 19, 2014 Now I'm getting the white box with line through it. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 19, 2014 Author Share Posted May 19, 2014 On post 26 2nd pic. The sponge thing the connector should be just above there. You can see on my pic you have the sponge and then tiny bit further up is connector. Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted May 20, 2014 Share Posted May 20, 2014 Will try and have look weekend but it's hard to get to alot of bits need removing Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 20, 2014 Author Share Posted May 20, 2014 No point the connector is not there already had a look today it's just not anywhere. Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted May 20, 2014 Share Posted May 20, 2014 Yeah but we have different wiring looms. Is yours a 7 pin connector or 10 pin? Only a 10 pin connector would have it Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 20, 2014 Author Share Posted May 20, 2014 I have a 10 pin as well. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 20, 2014 Author Share Posted May 20, 2014 10 pin to the headlights. I've had a full search today the connector on my car just isn't there. You have to mod a cable in or just rewire you dash. I rewired dash and it was a headache. I'm going to use elm config to check if I can connect to it. Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted May 21, 2014 Share Posted May 21, 2014 The part of the wiring harness with the hid module how is it connected to the rest of the wiring? Conbector block or some sort of solder joint? Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 21, 2014 Author Share Posted May 21, 2014 I rewired my whole dash to get the hid module connector. So the loom I'm my car now is a focus rs one. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 21, 2014 Author Share Posted May 21, 2014 But I only done it as I had wireing issues airbag light etc. I'm sure jw should know what to do . I'm completely lost on that. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 21, 2014 Author Share Posted May 21, 2014 My old loom don't have that connector at all. Look at the pic I upload 2mins I get it. Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted May 21, 2014 Share Posted May 21, 2014 It seems my other post wasn't sent correctly but I did ask, does your old loom your 10 pin factory loom have wiring for front sensor already on the car? Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 21, 2014 Author Share Posted May 21, 2014 Yh it has the xenon front sensor loom. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 21, 2014 Author Share Posted May 21, 2014 It all goes tgrought the gem module big blue connector. Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted May 21, 2014 Share Posted May 21, 2014 On the wiring schematics, sensor loom goes directly to the hid control module, there is no other cables connected to it. Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jord0410 Posted May 21, 2014 Share Posted May 21, 2014 Guys have a look at my post I'm having similar problems Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
jord0410 Posted May 21, 2014 Share Posted May 21, 2014 If you wouldn't mind Sent from my iPad using Ford OC Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 21, 2014 Author Share Posted May 21, 2014 I've never traced it back from there but it must lead to gem as the hid module connector is part of the dash loom. I've got the level sensors wiring and 10 pin headlight connector. But my old loom had no xenon module connector. The only way you can do it is rewire dash or create your own connection. Quote Link to comment Share on other sites More sharing options...
jord0410 Posted May 22, 2014 Share Posted May 22, 2014 What motor you got naz? Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 22, 2014 Author Share Posted May 22, 2014 Ford Focus 1.6 mk2 Quote Link to comment Share on other sites More sharing options...
mixmasterlooney Posted May 22, 2014 Share Posted May 22, 2014 Based on the wiring schematics I will have to take a look at my car wiring and trace it back to see because sensor wiring go directly to the module and if the module isn't there but the sensor is where does the other end of the sensor go? Can't be gem as that has no control over the sensors that's what the hid module is for Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 22, 2014 Author Share Posted May 22, 2014 I'm not sure. I had loom on outside. But the loom inside car don't have the loom Quote Link to comment Share on other sites More sharing options...
